Old 06-10-2013, 03:42 PM   #1
FourWheelers's Avatar
Trim for bunk door
Anyone know who might sell the trim for the edge of the fold out bunk doors on a 2010 Rockwood Roo 233S? It is a white clip on trim with rubber gasket to seal against the side when closed.
FourWheelers is offline   Reply With Quote
Old 06-10-2013, 03:45 PM   #2
Fulltime family RVer
You likely will need to contact a dealer and see if they can place an order for you.
Old 06-10-2013, 03:50 PM   #3
I've been waiting for the factory to get back to my local dealer with a price. I just figured it would be faster if I could find this moulding / trim on my own. Rockwood can not be the only one using this particular trim.
Thanks for the reply.
Old 06-30-2013, 07:16 PM   #4
Okay. Got my pinch welt and black pad seal installed on the two leaking bunk ends.
Works great! We are in a rain pattern here in New Jersey and I'm happy to report no leaks. I made sure to overlap the upper welt to the sides and caulked the corners where they met. I also caulked along the bunk canvas where it connects to the trailer and used new gasket glue on the existing black moulding.
I replaced the old black pad seals on the latch handles for a tighter seal.
This seams to have corrected my leak issues. As soon as I get a dry period, I will do the same to the remaining bunk. It doesn't leak right now but some preventative maintenance couldn't hurt.
Old 08-20-2013, 09:45 AM   #5
UPDATE
I replied to another thread with this so I apologize to anyone reading this twice.
After replacing all trim and seals associated with the bunk ends of my 2010 Roo, I went out this morning to find the mattress wet. It appears all my work on the bunk ends failed to fix the problem.
If anyone knows of another fix or factory modification to the 2010 series to address this issue, please let me know. There seems to be way to many owners with the same leaking bunk ends issue for Forest River not to be aware.
Old 08-20-2013, 10:18 AM   #6
Brother Les's Avatar
Forest River is aware......
Brother Les
Old 11-02-2013, 06:41 PM   #7
And what are they doing!!!!!
mvaughan is offline   Reply With Quote
