Old 05-30-2016, 11:59 PM   #11
Originally Posted by joinco70 View Post
I'm a novice, but it's my understanding that you want to connect two 6v batteries in series, not parallel. Correct me if I'm wrong though.
You never said 12V or 6V, so I think theengle assumed they were 12V.
If they are 6V and if you've rotated one 180 degrees, then it looks like you've got them properly in series.
2011 Traverse LT, 3.6L, FWD
Old 05-31-2016, 05:05 AM   #12
they are correctly in series...and clearly each are 6 volt units since they only have 3 cells.
2015 335DS
ScottBrownstein is offline   Reply With Quote
Old 05-31-2016, 06:22 AM   #13
My bad, I thought they were 12v batteries that you trying to connect in parallel. Since they are 6v batteries you do need to put them in series, the positive of the left battery should be connected to the negative of the right battery.
theengle is offline   Reply With Quote
