12-01-2019, 04:33 PM
Troubleshooting Electric Tongue Jack
2014 forest river roo - 233s. Fic 3500 electric tongue jack
Jack lost power was able to troubleshoot the issue and found the circuit breaker inside the unit to be the issue
When I push the red area to the copper area jack works.
Any dangers I should be aware of if I connect w electrical tape until I can find a new part? I can get the jack to work w electrical tape - just dont want to do any damage to my electrical system
See pics
12-01-2019, 06:28 PM
Brake is on left
That looks like the overload switch. As long as there is a fuse on the power wire to the battery (which there should be) it'll be ok for short term use. Worst case is you smoke the jack motor and blow the fuse.
12-01-2019, 06:31 PM
Awesome feedback. Thank you!
12-01-2019, 06:55 PM
Any idea where I would pick up a replacement? Not much Im finding online ...
12-02-2019, 11:02 AM
it is likely that is just a 50 AMP fuse... remove it and it will probably say somewhere the rating... Autozone or NAPA autoparts stores should have one.
or check this on amazon...
https://www.amazon.com/RKURCK-Circui...302476&sr=8-26
Too much of anything is bad, but too much good whiskey is barely enough. Mark Twain
2014 Shamrock 183
12-02-2019, 11:09 AM
If you just bypass this switch you may be able to use the jack for a long time without problems as long as you are careful to not overheat the motor.
It appears to be a thermal limit switch to protect the motor should one use the jack too often. A fuse will prevent over-current but if the motor overheats due to too frequent use at loads under what the fuse is designed to "blow" at, heat will destroy the motor. Usually a problem when people attempt to lift both trailer tongue and tow vehicle rear end to make it easier to attach WDH bars.
My guess is that the part is a proprietary design and may only be available as a replacement part from the jack manufacturer.
Sami. my Shih-Tsu "Co-Pilot" R.I.P
Politically Incorrect since 1943
"Sometimes you're the dog, sometimes you're the tree"
2004 Nissan Titan
12-02-2019, 11:15 AM
Originally Posted by rsdata
According to what I have read - they actually call this a circuit breaker (20a). Thanks for your feedback!
12-02-2019, 11:16 AM
Awesome - thx for taking the time to comment.
12-02-2019, 11:19 AM
Great feedback - thank you.
12-02-2019, 11:28 AM
You need to get the current rating from the case and you should be able to find a replacement at an auto parts store. You can get them from the Mfg but they are more expensive than auto parts. ( etrailer)
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
12-02-2019, 11:36 AM
2016 F150 XLT 4X4 SCREW 5.0
2014 Grey Wolf 21RR
12-02-2019, 01:45 PM
you can get it on Amazon
12-02-2019, 02:20 PM
Brake is on left
This may not be the correct current rating so check yours to make sure.
https://www.etrailer.com/Accessories-and-Parts/Lippert-Components/LC134181.html?feed=npn&gclid=EAIaIQobChMItdizlteX5 gIVBYiGCh2oVQJnEAQYBSABEgJDyvD_BwE
12-02-2019, 03:32 PM
FLY4FUN
TitanMike wrote: " people attempt to lift both trailer tongue and tow vehicle rear end to make it easier to attach WDH bars."
...not meaning to hijack, but I've been doing this^ with my new-to-me TT. I've always raised the tongue/TV rear by hand cranking the tongue jack with previous TTs, but had never had the electric jack until this one. Am I seriously cutting the life of my jack...and, is there an alternative? With these old rotator cuffs & sore joints it's almost an impossible task to totally lift & latch the WDH. I'm hoping that I'm missing an "easy" (relative  ) alternative to using the electric jack. 14
12-02-2019, 05:52 PM
I have raised my truck with the electric jack since I got it back in 2014... no problem, but I don't raise it past what I need... I listen and look at the rate and when it begins to slow down because of stress I stop...
2014 Shamrock 183
12-02-2019, 05:57 PM
I had a Ultra Fab power tongue jack for 10 years, until I sold the trailer. Never missed a beat and was still working when I sold the trailer.
Equalizer WDH
12-02-2019, 06:44 PM
The point in my comment was that the device in question might be a thermal limit switch to protect the jack from damage.
I use my jack to lift the rear of my truck (some) but am always conscious of how hard it's working so I've never hit a thermal limit or blown a fuse (and hope I never do).
2004 Nissan Titan
Yesterday, 06:49 PM
Yeah, that means that there isn't an in line fuse. I definitely would not disable it (by taping it closed like you did) if the circuit is overloaded there must be a reason for it you must find that reason and corrected. Getting rid of that protection could cause your trailer to catch on fire. Be careful
