Old 07-11-2016, 01:31 PM   #11
DouglasReid's Avatar
Originally Posted by Just so fine View Post
Not sure this is your problem, but I had a leaking AC for two years. Did all the things mentioned in other posts to no avail. Then one day I switched my fan from hi to low and the leaked stopped. Seems in hi humidity situations the holding pan filled to fast and overdeveloped flowed in to the RV. On low it had time to drain out. Just what happened to me.
We live in S Louisiana and it is nothing here if not humid.
Sometimes if the unit is not perfectly level water will pool where there is no drain.
If it is such a drainage problem, take the cover off, let it run an, see where the water pools.
Drill a hold there to let out the water before it overflows into your camper. (Put a block of wood under the pan so you don't accidentally slip and make a hole in your roof)
Put the cover back on and never look back.
Maurice, LA
2012 Wildcat Sterling 32RL
2008 Chevy Silverado 2500HD LT Diesel
TST TPMS system w/ Flow-thru sensors
2001 Cougar 281 EFS (sold)
DouglasReid is offline   Reply With Quote
Old 07-11-2016, 02:11 PM   #12
MartiB's Avatar
Thanks for the info. I had the same issue on a hot weekend with my Salem CruiseLite. I thought my dealer said to use the high fan setting. Now I'll have to check to be sure I didn't hear it wrong.
MartiB is offline   Reply With Quote
Old 07-11-2016, 02:22 PM   #13
Herk7769's Avatar
1) remove the shroud on your air conditioner (both halves) and clean out the drain holes in the floor pan. If there is standing water in an area, you can carefully drill a large(er) (1/4 to 3/8 inch)diameter hole to aid in drainage. USE A STOP ON YOUR DRILL BIT to prevent drilling into your roof!
2) Remove the interior air handler cover CAREFULLY. You will need to use a razor knife or blade to cut the caulking that binds the plastic to the ceiling. DO NOT SKIP THIS STEP or you will ruin your ceiling's paper covering.
3) Examine the "torque tabs" on the air conditioner. They are the yellow tabs in the photo. Over-torqueing or uneven torqueing is usually the culprit if it only leaks during rain storms as the over compressed gasket will eventually fail on the rough EDPM roof material. Removal and gasket replacement will solve this problem.
ID:	113748   Click image for larger version
HAM CALLSIGN - KC3FFW
Old 07-11-2016, 02:37 PM   #14
If you donít have a first class drill stop like the one on Herk's photo, you can cut a piece of tubing to slip over the drill bit with the right length of bit exposed. Just don't press on the drill too hard and compress the tubing as it drills through. As a backup, maybe you can slip a piece of sheet metal behind where you are drilling.
RamblerGuy
2011 Sunseeker 3100
1997 Pathfinder Toad
leak
