Old 05-24-2019, 09:36 PM   #1
Toppans's Avatar
Truck front end “swim”
Hi everyone, not sure if I have a problem or not. We changed out our hitch to an Andersen WD hitch. We have made two short trips, one an hour away and another two hours away. With everything hitched up and ready to go the truck is level and the camper is just about level, maybe a little nose high. My problem is the truck feels different when on the road than our old WD hitch with the heavy bars. The front of the truck seems light, like it sways or swims. I don’t have control issues but it doesn’t feel right. I have the truck and trailer loaded the same way as we did with the old hitch, but do I have the trailer loaded wrong for this hitch? Do I need to move more weight to the front or back of the camper? We have a 2018 24WS Roo and towing with a 2016 Silverado 1500 tow rated at 9200 pounds. Thanks for your input and help!!
Toppans is offline   Reply With Quote
Old 05-24-2019, 09:58 PM   #2
Scoundrel
HangDiver's Avatar
There are other forum members smarter than I about your issue. But a couple things that seem obvious to me:
1) A trailer that is nose high may not have enough weight on the hitch. Personally I like a trailer that is perfectly level or a tiny bit nose low;
2) You said your truck is level, but a better solution would be to have the front of the truck at the same height with and without the trailer hooked up. That is, the WD hitch is connected properly if the front fender height is nearly the same, with or without the trailer attached.
My .02
2014 Micro Lite 19fd
2015 F-150 5.0L V8 XLT Crew Cab, 4x4, Tow Package, 36 gal tank, 3.55 locker, 1891 payload, Integrated Brake Controller
Wooden Spoon Survivor
HangDiver is online now   Reply With Quote
Old 05-25-2019, 05:53 AM   #3
Sounds like not enough weight to the front wheels you might need to readjust to find the spot that works best for you.
2017 River Stone Legacy 38mb
2001 Kenwoth T2000
2008 Smart on deck
dblr is offline   Reply With Quote
Old 05-25-2019, 06:58 AM   #4
Chuck_S's Avatar
You've distributed any weight from the rear to the front axle.
Ya gotta measure the truck's height unloaded and then with the trailer connected. Easy at the wheel wells, just get a yard stick. Both suspensions must compress. I'm betting your front is not lower when connected which means you've taken weight off it.
"Level" is meaningless. You need to bring the truck back to what it was unloaded which is seldom "level."
You can replace the rear shocks with steel struts (OK, rubber thingies in the springs) and the rear end will stay "level" and not accomplish a thing regarding proper weight distribution.
Trailer frame should be level or slightly down at the front. Up at the front will unload the truck rear axle (and brakes) in hard stopping events.
-- Chuck
Chuck_S is offline   Reply With Quote
Old 05-25-2019, 07:37 AM   #5
Why the switch to the Andersen ?? If I may ask.
TheWolfPaq82 is offline   Reply With Quote
Old 05-25-2019, 07:42 AM   #6
Without numbers from a scale....you have no clue where or how the weight is being distributed.
Old 05-25-2019, 07:45 AM   #7
Oaklevel's Avatar
Personally I doubt that the way the trailer loaded is the problem. I have never had to worry about a camper, my box trailer yes.
But without knowing more I think the way the WDH set up is the issue.
I would take the rig to a CAT scale weigh it with and without the WD set up and with the truck solo and see what is going on. Be sure to use all 3 scale pads.
Good Luck.!!
2005 Dodge 3500 Cummins
2017 Wildwood Lodge 4092 BFL
1966 Mustang GT
1986 Mustang SVO
Oaklevel is online now   Reply With Quote
Old 05-25-2019, 08:12 AM   #8
cmac7203's Avatar
I have an Andersen. TV Ram 2500, TT 8500 LB. no problem leveling. OTHER issue is returning enough weight back to front axle. The sweet spot for Andersen is 7-8 threads showing AND 1/4” or so bulge on bushing. You MAY need to take up a link on the chain to ensure BOTH conditions are met. That should return most or all of the weight back to front axle. Another person on here runs with 9 threads when he goes heavy.
2019 Rockwood 2707WS
2009 Ram 2500 5.7/3:73
cmac7203 is offline   Reply With Quote
Old 05-25-2019, 01:09 PM   #9
Chuck_S's Avatar
Sure you do.
The springs will compress/decompress as weight is transferred to/from them. Again, if the front suspension does not compress no weight is being added. And, of course, of the front suspension de-loads you took weight from it. A $2 Walmart yard stick will provide the relative answers.
-- Chuck
Old 05-25-2019, 01:14 PM   #10
jkoenig24
I'm sorry I don't have a solution for you but DO continue to listen to what your truck is "telling" you and also to the seat of your pants re the ride.
jkoenig24 is online now   Reply With Quote
truck
