Old 07-17-2016, 03:28 PM   #11
Originally Posted by MiCamper6 View Post
And I still can't figure out why there would be a problem with putting a locking door handle on a bathroom door??
my kids love to try and open the door, I'm definitely putting on a lock!
berdmann is offline   Reply With Quote
Old 07-17-2016, 03:43 PM   #12
Moderators' Assistant
bikendan's Avatar
Originally Posted by berdmann View Post
I am in the homebuilding industry and am familiar with a reflective house wrap to put overtop of the Tyvek before vinyl siding or stone or whatever. Are you using a similar product to custom make a covering of some kind to go inside or outside the tent end?
Or are you just cutting out a piece the shape of the windows and zippering it between the vinyl and the screen parts?
First, Google Popup Gizmos. It will explain how they work.
You can make your own with Sportsmen/All-weather blankets from Cabelas or Bass Pro or REI.
The Reflectix is reflective bubble wrap used in homes.
It comes in rolls and Lowe's and HD carry it.
We cut out sections to put in the tent windows, between the screens and the widow flap.
Dan-Retired Firefighter/EMT
2016 PrimeTime TracerAIR 255, pushing an '07 Chevy Avalanche
Equalizer WDH and Prodigy BC
Old 07-17-2016, 06:46 PM   #13
Suggest you do a couple days driveway camping before your first trip, if possible. That way you can try out all the systems in the camper, making sure they work as intended, instead of being at a campground miles away.
Of course, all systems should be covered in your pdi, but in case you forget something, you will have time to call the dealership for info.
As previously mentioned, season the tent ends.
Make sure battery is fully charged.
Have fun and good luck.
Jim and Deb
Many times..asst grandkids
2015 Shamrock 23ikss
2013 Ram 1500
jking46 is offline   Reply With Quote
Old 07-17-2016, 07:36 PM   #14
Old Eeyore's Avatar
As far as I'm concerned none. Provided that the door can be easily - and quickly - unlocked from the outside. I would never want a kid on the wrong side of the door unable - or unwilling - to unlock it.
When our kids were small we installed emergency door lock release striker plates on most of our home's interior doors. The door locked normally but you could give the door a quick hip check and it would open nothing flat. No key to find.
I'd do the same with our camper if we had little ones with us regularly. Privacy can be tough enough in a camper. Some folks might be hard pressed to take care of their business if they knew nothing would stop someone from opening the door in the middle of things.
Of course, given current construction materials and techniques the wall may come down with the door. . .
2016 Roo 23IKSS / 2011 Tahoe
2011 Roo 21SS / 2011 Tahoe
2006 Bayside / 2006 4Runner
1999 SantaFe / 2001 Sienna
1967 Nimrod / 1998 Outback
Old Eeyore is offline   Reply With Quote
Old 07-17-2016, 07:56 PM   #15
MiCamper6's Avatar
The locking door lock I installed in my Roo unlocks automatically with a twist of the interior door handle. It also came with a simple straight 'pin' with a loop on the end that will unlock the door when pushed into the small hole in the center of the external door handle. Therefore it is virtually impossible for anyone to get locked in the bathroom, and it is easily and quickly unlocked from the outside as well. Much better than having my young daughter walking in on me, and vice-versa (both of which have happened).
MiCamper6 is offline   Reply With Quote
Old 07-17-2016, 08:20 PM   #16
Old Eeyore's Avatar
We had those on the doors too. Simple operation and worked well for many years and I was thinking that installing the striker plates was a waste of time. But - one stormy night our DD was in the bathroom when the power went out. It was like a cave in there. She panicked - couldn't move - just screamed and screamed. The hall was just a dark and my DW fumbled for the key - but never found it. She screamed. I hip-checked the door and all was well. . . after I got my heart rate down. (Nothing like a nasty thunderstorm accompanied by little girl and big girl screams to get a guy's ticker thumpin'! )
Old 07-26-2016, 08:45 PM   #17
jrfops
jrfops's Avatar
Our smoke detector was not installed tight, and came off during travel. When we opened the slide, we heard a loud crunching noise. Luckily, only the smoke detector was damaged. We installed the new one so it's not over the slide. Also, put a 4 in 1 screw driver in trailer. The screws in our trailer come loose a lot.
jrfops is offline   Reply With Quote
