05-02-2016, 11:39 PM
Warped Sink Cover Cutting Board
I purchased a 2016 Roo19 last summer. As with many first time RV owners, I didn't know everything to look for during the dealership PDI walkthrough. After bringing my new rig home, I noticed the white plastic kitchen sink cover had a 1/2 inch bow in it that doesn't allow it to sit flush with the sink. Does anyone have any suggestions how I can flatten it out to get it to sit flush? I suppose I could try a heat gun to try and flatten it out but I'm concerned about melting it. Thanks in advance for any suggestions. Fly Navy!!!
2016 Roo19 Hybrid
2015 GMC Sierra 4x4 Crew Cab
05-03-2016, 12:38 AM
I'd try supporting each end and putting a weight in the middle for a day or so and see what happens. If it doesn't stay flat, maybe shot some heat to it.
(SH-3D electrician; 1970-74 - Do it in a hover!)
2011 Traverse LT, 3.6L, FWD
05-03-2016, 01:49 AM
a lot of us have found that the sink covers are almost useless as cutting boards and replaced them with other ideas, .... I found a youtube video of a 2015 model and the sink in it appears to match what we have in our trailer,... below is the link to a post of a very simple idea that gives added counter space and can use any cutting board that you prefer,...... hope this helps
http://www.forestriverforums.com/for...dea-93664.html
05-03-2016, 04:21 AM
Outside on a warm sunny day, support each ends, put some weight in the center and let the sun do the work
Dre
05-03-2016, 11:32 AM
I have the same issue, but mine matches the counter. I will be replacing it with a wood cutting board. Ours was not meant to be a cutting board. I use the sink when traveling to put my fruit in to keep it from bouncing around getting bruised. If I can find a cutting board large enough, I will have my husband cut it so it is the same shape of the sink.
Chuck & Denise + Pata, The Purple Princess Peanut, Ziggy the pole cat and Kazumba the parrot
2015 23 BD Gray Wolf
2008 Dodge Ram 2500 TX Edition 2015 - 7 nights, 2 trips, 2016 - 2 trip, 24 nights, 2017 1 trip, 3 nights 2018 1 trip, 93 nights
05-03-2016, 01:25 PM
Sink cover
Had this problem when I got my 21 VFB home. Put the sink cover under mattress and left it there until went camping. It fit fine.
05-03-2016, 03:37 PM
Warped sink cover
I put mine on upside down with three full water bottles in the midddle. Left it that way for a few days and it is fine again. Whenever we are not camping I just turn it upside down. When on the road I turn it over. I just want it to stay in place while we are moving and when extra counter space is needed.
05-03-2016, 04:34 PM
I have the same issue. I will put in the sun with weights on it to flatten again.
2014 Ford F250 Super Duty, 6.7L Diesel, Ultimate Lariet package
2016 Forest River, Heritage Glen 272RL
05-06-2016, 04:05 PM
Dre
X2 - worked for ours. On the patio table with a big weight in the middle and a couple of days in full sun.
But we would probably only use it if we really needed more counter space. (An unlikely situation in a 23IKSS)
Just got to store it flat somewhere instead of on edge in a cabinet - which probably caused the problem in the first place.
2022 Rockwood 2608BS / 2019 Silverado 1500
2016 Rockwood Roo 23IKSS / 2019 Silverado 1500
2011 Rockwood Roo 21SS / 2011 Tahoe
2006 Fleetwood Bayside / 2006 4Runner
1999 Coleman SantaFe / 2001 Sienna
1967 Nimrod / 1998 Outback
05-08-2016, 10:54 AM
I think these cutting boards come warped from the factory. Instead of trying to straighten it out I made a new one from 1/2" material. I started by tracing the form onto the new stock and cutting it out.
Then routed groove on back side for tight fit
Then cut in half so I can still use the sink
and finally cut the finger holes
This board is very sturdy no movement or bend at all.
Stephan
2016 Roo 21ss
05-08-2016, 01:31 PM
We got a 2016 shamrock 233s when we did the PDI we noticed ours was bowed too, now after opening the camper for spring it's bowed again, so I'll just have the dealer replace it under warranty again .
05-08-2016, 01:38 PM
FR told our dealer that these things warp due to being inside hot RVs. Replacing it with another just like it simply means that one will warp, too.
We're going to replace it with something far sturdier and more useful, as did 1982 Ironhead.
2016 Rockwood 2906ws, 2014 Ford F-350, one cat.
05-08-2016, 04:26 PM
[QUOTE=1982 Ironhead;1188692]I think these cutting boards come warped from the factory. Instead of trying to straighten it out I made a new one from 1/2" material. I started by tracing the form onto the new stock and cutting it out
Awesome. That is just what I was thinking except in wood. What type of plastic did you use and is it safe to use as a cutting board?
05-08-2016, 05:42 PM
It is actually a winco cutting board I bought on eBay. Winco 18 inch by 24 inch by 1/2 inch white cutting board made of polyethylene plastic with a non-porous surface that won't stain or absorb juices. Dishwasher safe and NSF certified.
Stephan
2016 Roo 21ss
05-09-2016, 09:28 AM
Nice job!😊
05-09-2016, 11:34 AM
Take the factory sink cover/cutting board, wrap it in plastic, such as a kitchen bag, to keep it dust free, then place it flat somewhere up in your garage attic, only pull it back down when you sell or trade in your Roo. That's where mine is located currently
*That custom job by Ironhead looks amazing. Adding that to my future mods list.
05-09-2016, 06:18 PM
I just took the cover out of it's flat storage place and found that it was back to the same useless shape. The dang thing has a memory!
Well. It's gettin' stored with the mattress we don't use and the next owner will have the pleasure of figuring out what to do with it.
05-10-2016, 10:24 AM
Mine stays under the sink, don't use it as it is worthless, buy yourself a good cutting board instead.
2016 F350 SCREW SB 6.7 PS Diesel
2015 FR Rockwood Roo 23IKSS
2016 F350 Supercew Short Box 6.7 PowerStroke Diesel
2013 Crusader 295RST Touring Edition
