Old 07-06-2014, 10:29 PM   #1
Watching movies
We have a 2015 Rockwood Roo 233s. With a genesis sound system. It has the DVD player and a USB port. We have several movies saved on to a flash drive (less DVDs to keep track of).. But we can't figure out how to play them. Maybe this setup won't play them. Does anyone know of a device that we can hook up that will play movies off a flash drive?
Jeff and Michele
with 3 kids (19, 16 and 11) and a new puppy
Towing with 2007 Ford F150
Camping in Colorado
cropper127 is offline   Reply With Quote
Old 07-06-2014, 10:37 PM   #2
asquared's Avatar
Plug sub into iPad and iPad into tv? I've seen my share plug the iPad in to watch his wrestling channel on tv at home before. I would tho k same concept for flash drive.
<a href=http://i62.tinypic.com/28rp645.jpg target=_blank>http://i62.tinypic.com/28rp645.jpg</a>
2014 Sabre 34REQS-6
asquared is offline   Reply With Quote
Old 07-07-2014, 06:34 AM   #3
Carlosrod's Avatar
After you plug your flash drive, take tv remote and press Mode in order to change the input. You should have the option of playing directly from the USB port. Works for me.
"Live" so that when your children hear the words Ethics, Integrity or Honor, they would think of You.
Live, so that when your children hear the words Ethics, Trust, Integrity and Honor, they think of YOU!
2015 Shamrock 23 IKSS Pushing a 2015 Durango R/T. Yeah, it's a Hemi
Nights Camped - 2013/17 - 2014/24 - 2015/22 - 2016/Pending
USMC - Semper Fi
Carlosrod is offline   Reply With Quote
Old 07-07-2014, 08:32 AM   #4
cogito ergo moo
Cowracer's Avatar
The sound system will not play movies via USB. Only mp3 audio.
Tim
FROG Member MO-0008-571 Since 20124444444444My Project Blog: https://cowracer.blogspot.com/
2016
Rockwood Signature Ultralite 8329ss
Rallies Attended:
Cowracer is offline   Reply With Quote
Old 07-07-2014, 09:26 AM   #5
Bummer. Is there a device I can get that will plug in?
Jeff and Michele
Camping in Colorado
Old 07-07-2014, 06:23 PM   #6
asquared's Avatar
There is a connector for an ipad (apple box says 30 pin digital AV adapter) that allows you to plug the iPad into the hdmi connector of a TV. You can then plug the usb into the iPad and run it that way. Not sure if your tv has an hdmi outlet or not. If you do have an hdmi outlet, this should work (Dh says this works on our home tv).
2014 Sabre 34REQS-6
Old 07-08-2014, 12:22 PM   #7
cogito ergo moo
Cowracer's Avatar
You cannot run any video thru the stereo USB, from any source. It cannot process video, only audio.
You can buy an HDMI cable from your laptop or tablet and run directly into the TV.
Tim
2016
Rallies Attended:
Old 07-08-2014, 12:32 PM   #8
Kaadk's Avatar
iPad's don't have USB in. I do use that connector to watch digital copies of movies on the TV from the iPad but it has to already be loaded on the iPad. It wouldn't be able to read from a USB stick.
To the OP, you're either going to have to convert the movies back to disks, or have some kind of computer(or tablet) on hand to play the files. If you're adventurous, you could pick up a Raspberry Pi (Raspberry Pi) and use it to play from USB direct to the TV, but in reality a netbook would probably be the easier choice.
There's no use crying over spilt milk, unless it's on your keyboard.
Old 07-08-2014, 01:09 PM   #9
thestrangebrew's Avatar
When I driveway camped in the new trailer I tried to do what the OP did and couldn't get it to work. Ultimately I unhooked one of my mini htpc setups from my sitting room and hooked it up to the hdmi input on the tv. Had to adjust the screen size but it worked flawlessly. A laptop/netbook/tablet with hdmi out is probably the only thing that will work.
There are other options if the CGs you go to have wireless internet services, not sure if this is something you might be interested in though.
2014 F-150 SCREW Ecoboost 4x4.
2014 Rockwood Roo 233s GVWR
thestrangebrew is online now   Reply With Quote
Old 07-08-2014, 01:11 PM   #10
dcheatwood's Avatar
Y'all got me curious now. I haven't tried video thru USB. Gonna try it soon.
Sent from my XT907 using Forest River Forums mobile app
2013 Rockwood 8282WS
Reese Revolution Pin, Reese 16K
2008 Tundra Limited Double Cab 5.7L
Air Lift 5000 w/Wireless Air
