09-15-2018, 06:18 PM
#21
Just put a water filter cap on the canister and reinstall it. No anti freeze goes in.
See my photo and link in the "other thread" running on this same subject.
-- Chuck
09-15-2018, 08:34 PM
#22
I don't have a dog but I will take his word for it.
2017 Flagstaff Shamrock 21ss pulled by a 2007 Ford F150 XLT 4X4
09-19-2018, 02:56 PM
#23
After my filter blew up in my camper, I took it out. Same thing happened to my father in law two weeks later. Those filters are a ticking time bomb.
Now I use an external filter. Cheaper and easier to replace too!
09-20-2018, 08:24 PM
#24
Delete the factory filter and use an external filter. Mine self-destructed in its second season and luckily I was right there to dry it out and prevent permanent damage. It’s not worth the risk to your camper when these break and cause quick flooding. With an in-line external filter, a filter failure is just a wet driveway or campsite! There is no extra step with winterizing when the filter is deleted.
Velosprout
2014 F150 SCrew 4x4 Max Tow Heavy Duty Payload 3.5 Ecoboost 6.5' bed Ingot Metallic Silver
2015 Rockwood Roo 21SS
09-23-2018, 09:21 AM
#25
What broke? If water pressure is that high I'd suspect damage to the plumbing system as a whole. Pressure regulator is recommended.
-- Chuck
09-23-2018, 10:53 AM
#26
HI Chuck, i don't totally understand forums so how/where do I see your photos and where is the "other thread? Thanks.
09-23-2018, 11:04 AM
#27
Too many similar threads running in different areas.
Water filter block-off plate. <-- that's a link to one source.
No wasted RV antifreeze.
Nothing more than a stainless steel plate and rubber gasket.
-- Chuck
09-23-2018, 11:20 AM
#28
-- Chuck
Actually , this is a another good idea. I don't see any reason that it cannot be just left in and use an external filter instead. I've gotten into the habit of using the external filter on the spigot before the hose .
09-23-2018, 01:17 PM
#29
I changed from the standard filter to a residential one and it has a bypass mode so should just be a drain operation and no extra antifreeze
2024 Artic Wolf 3018 Suite 5th Wheel
Prior TT Grand Design 2800BH TT 2021 - sold 4/24
Prior TT 2017 Flagstaff 831CLBSS Classic Ultra lite - SOLD 5/21
TV 2024 F350 DRW Lariat Ultimate
Prior TV 2017 F150 6.5' bed 3.5 Eco-boost Max tow 1800lbs payload - sold 4/24
09-23-2018, 09:05 PM
#30
Thanks, Chuck. I will get one of these and use it in a few days when I winterize my unit.
09-23-2018, 09:35 PM
#31
Installed this filter in place of the factory unit. To replace the filter it swings up from the bottom then pull out. When you swing it up it is in bypass.
2016 Flagstaff 27VRL with overloaded tires from factory
2015 Chevy Silverado
09-23-2018, 10:02 PM
#32
Kasual Kamper
Where is that filter located on your rig?
Current: 2013 Flagstaff MicroLite 21DS
Past: 2000 Fleetwood Mallard 19N
TV: 2013 Nissan Pathfinder SL 4x4
09-23-2018, 10:04 PM
#33
Thanks, that looks like a good unit.
09-24-2018, 05:08 AM
#34
It’s in the same cabinet as the factory unit was, just moved a little it needs the door space to swing out.
It’s a whole house filter, the replacement cartridge is $49 but I am pretty sure I can get a year out of it. No worrying of the bottom is screwed on tight enough or if it will pop off.
In the 27VRL it’s under the street side bathroom sink, the sink closer to the toilet.
09-24-2018, 07:03 AM
#35
Kasual Kamper
That makes a whole lot more sense that where most of them are located in trailers these days.
10-17-2018, 02:08 AM
#36
Camper Bruce
water filter
i put a small bucket under mine and let the water spill into the bucket, then remove the bucket - filter and outside filter holder.
