Old 07-01-2014, 04:55 PM   #1
Water filter
Okay with the thread about the water filter bowls unscrewing themselves I'm now a little worried. So I want to have a repair kit ready to go. What do I need if I want to just bypass the filter of it becomes a problem. Is it just 1/2" inside diameter pex piping and a couple barbed fittings that I would need to remove the filter and connect the input and output lines?
RACKMAN
2014 Roo 21ssL...towed by 2015 Ram Power Wagon
RACKMAN is offline   Reply With Quote
Old 07-01-2014, 05:16 PM   #2
That is exactly what I did with mine never put water thru it after reading the problems others had just took it out and put in pipe with shark byte fittings. Then I us the same filter externally.
2003 Dodge Ram 2500 5.9 Diesel
2014 Rockwood 2608WS
Big Paul is offline   Reply With Quote
Old 07-01-2014, 08:55 PM   #3
Can I get the parts just to bypass at home depot? I just want to take it off and put on a pipe for now, worry about configuring an external filter later!!
hockeyfam is offline   Reply With Quote
Old 07-01-2014, 09:00 PM   #4
Ford Idaho's Avatar
Home Depot or Lowes, ACE might have them.
Pull the filter housing out and take it with you so you get the right size, explain what you want to do someone should get you lined out.
Old 07-01-2014, 11:45 PM   #5
Grizzlygibbs's Avatar
It should have 1/2 male pipe thread going into the filter. Mine did on my 233s. I replaced with a GE water filter. Holds tight.
If yours does you should be able to use a couple of 1/2 threaded couplers and a threaded pipe.
2008 Toyota Tundra Crewmax Limited w/tow mirrors, 5.7L, 4.30 gears, six speed tranny, towing package, Firestone Ride Rite airbags.
2014 Rockwood Roo 233s, PI HW30-C, Equalizer 10k 4 way hitch,
Grizzlygibbs is offline   Reply With Quote
Old 07-02-2014, 04:53 AM   #6
I agree. If your going to the trouble and expense of bypassing why not just replace it like I did and you can use a standard filter.
Les & Heidi Kramer
2010 GMC Sierra SLE & 2014 Shamrock 23IKSS
Cleveland, OH
cpd1343 is offline   Reply With Quote
Old 07-02-2014, 06:20 AM   #7
The reason I went the route I did is because I like knowing that whatever I put in the tank will not have odor and will be protected from cysts and bacteria with the filters I get. I am not always on a city connection.
Old 07-02-2014, 06:14 PM   #8
urocav2001's Avatar
Any pictures of people installing a he style one?
urocav2001 is offline   Reply With Quote
Old 07-02-2014, 06:14 PM   #9
urocav2001's Avatar
Oops GE style filter
Old 07-02-2014, 06:26 PM   #10
DK-in-SC's Avatar
Question... the general consensus is to get rid of the factory water filter. No problem with that. But as I looked for other options, it got me to thinking. If I use an inline Camco style water filter on the hose coming into the camper, that will do a good enough job for the sinks, shower & toilet. So for drinking/cooking, what about installing a sink filter / faucet combo at the kitchen sink? Like one of these:
http://www.amazon.com/Culligan-RV-EZ.../dp/B002Q0XSNS
The hardest part would be making the hole in the sink. Anyone tried this in their Roo/Shamrock? I've got a 23IKSS so installing it in the island cabinet would be a breeze as long as I can get the hole in the sink. The filters look easy to change and they have several different filters available depending on how much bad stuff you want to eliminate.
I live with fear every day, and sometimes she lets me go fishing.
2015 Shamrock 23IKSS
2008 Ford Expedition EL
DH-DW-D3K-DMTTSAP
DK-in-SC is offline   Reply With Quote
water, water filter
