06-27-2014, 10:19 PM
Water heater
When we did our PDI we were told the water heater worked on both gas and elec. We have run it on gas just fine but can't figure out how to run it on elec. Supposedly we can use both at the same time to get hot water faster. Anyone help with this? Thanks.
06-27-2014, 10:28 PM
Go outside of your trailer and open the access panel to the water heater. Down low, on the left side as you face it, and hidden in behind some other hardware, is a little black electric switch. That's where you turn it on for electric operation.
Crazy, I know...
Mike and Yvonne
and Sophie, the little white dog
2017 Columbus 320RSC
2021 Chevy Silverado 3500HD DRW 4X4 Duramax
It's not how old you are, it's how you are old. ― Jules Renard
"It's not the years...it's the mileage." - Indiana Jones
There should be a switch on the outside. Remove the panel and look on the left side and turn that on. The 12v switch should also be on.
06-27-2014, 10:32 PM
Thanks for the info. We'll check it out in the morning.
06-27-2014, 10:43 PM
why didn't your PDI tech show you where the electric switch was, instead of just telling you that you have an electric side to the WH?
another example of a poor PDI when they don't show the customer such a basic and important feature of the RV.
06-27-2014, 10:50 PM
Don't forget to turn the electric switch off after you are done (at least that is what we do).
2013 Rockwood Roo 23ss
2012 F150 Ecoboost
Camped for 12 nights in 2015 - too many cancellations
Camped for 25 nights in 2014!
Camped for 24 nights in 2013!
06-28-2014, 08:10 PM
Well Put. While my tech was good and helpful, he was new and missed a lot of things. He did use a checklist, but he missed things that I needed to know like the manual over ride for slide out operation. As simple as that sounds, as a new owner I had no idea where it was until I figured it out myself.
I had no idea about that electric switch. I've read most of my manuals and probably over looked it.
Thanks for this information. Now I know about it!
06-28-2014, 08:25 PM
Do not turn the power to the heater on without water in the tank.
06-29-2014, 03:01 PM
10-4
Thanks for the reminder.
06-29-2014, 03:05 PM
I leave the switch on the outside in the "ON" position and operate it electrically from the inside control panel. If you're in a hurry to heat up the water, use both electric and gas. We run usually run it on electric and let the CG pay for the power.
2013 Palomino Columbus 320RS
2007 Dodge RAM 2500 6.7 Cummins
Reese 15K manual slider
Prodigy
M.I.L. in Florida for good!!
06-29-2014, 09:31 PM
So how does it default to electric if the gas is turned on as well? So the wall switch is the master switch I am assuming. I guess my question is does the water heater default to electric if the switch is always on?
06-29-2014, 09:40 PM
As originally outfitted, Yes
06-29-2014, 09:50 PM
It doesn't exactly "default" to electric, as your refrigerator does once you plug into shore poser. The water heater can run on gas only, even if you are plugged in at the campground, or on electric only, or on both if you want to heat the water pretty quickly. User's choice, not a "default" system at all.
Mike and Yvonne
06-29-2014, 10:10 PM
I had the electric thermo fail once. I noted it was set to close at 10 deg. less than the gas stat. That's the "automatic or default" means of elec. before gas.
06-30-2014, 11:18 AM
I'm confused. Maybe I'm missing something. How do you run it on both? I'm assuming you have the electric switch on the water heater turned on and the heater switch on the panel turned on?
If so, then how do you run on only electric? Same setup with the propane tanks turned off is the only thing I can think of. That doesn't seem very convenient for using the other appliances.
06-30-2014, 11:54 AM
If you want to utilize only electricity to the hw heater, flip the switch outside for electric. If you want gas and electricity, flip the switch outside for electric and the inside switch for gas.
We've never run both personally but we are a family of three plus the dog.
2012 F150 Ecoboost
06-30-2014, 12:18 PM
QFT!!
One note on electric water heating...it is slower than propane. If you have a lot of folks taking showers and so forth you may want to leave it on propane.
Nights Camped: 2013 - 24 2014 - 42 2015 - 56 Jul 2016 - Fulltime
06-30-2014, 12:31 PM
To clarify a little, if you have the electric switch on the outside and are on shore power, the wh will heat with electric. If you leave the electric switch on the outside on and connected to shore power, you can flip the switch on the inside control panel on and the gas will also come on with the electric to heat the water faster. If you leave both switches in the on position and unhook from shore power, the gas will heat by itself. There is NO automatic default to electric. Just make sure that you always have water in the water heater tank regardless of whether you are on electric or gas or both.
