Old 05-02-2015, 05:32 PM   #1
Water heater
When I am camping can I leave my electric hot water heater on the whole time or should I only turn it on when I need hot water
jhobson is offline   Reply With Quote
Old 05-02-2015, 06:01 PM   #2
mcnabbwr's Avatar
Just be sure there's water in the tank to prevent the element from burning out and leave it on. You don't want to wait for the water to get hot if needed.
Bill & Pam
2014 Trilogy 3650RE
2015 F350 PSD
mcnabbwr is offline   Reply With Quote
Old 05-02-2015, 06:35 PM   #3
RSchleder's Avatar
I agree! Leave it on as turning on/off heating elements is what causes the element to eventually burn out. It's all about the heating/cooling of the element that causes it to become brittle and eventually the metal fractures.
Incandescent light bulbs suffer the same fate. Saw a tv program about the oldest "living" light bulb known. It has been ON for well over 100 years. That is enough evidence for me!!!!
Days camping (2016)----181 days
Days camping (2017) --- 82 days
2016 Wildcat MAXX 28RKX (33' TT), 2007 13' Scamp
2015 Ram Laramie Hemi, w/air suspension
30 years RV'ing
11 different RV's
RSchleder is offline   Reply With Quote
Old 05-02-2015, 06:45 PM   #4
wmtire's Avatar
One thing to always remember if you have a 30 amp trailer or are hooked to 30 amp outlets....is the electric heating element draws 12 amps when it is heating.....leaving you 18 available amps to run EVERYTHING else.
You may run into breakers tripping when running the air conditioner, microwave, and/or other high amp appliances...... and the electric heating element comes on at the same time.
You usually encounter this in the morning and evenings if people are taking showers and making breakfast or dinner (toasters, hot plates, microwaves, and especially hair dryers) as the other appliances use a bunch of amps. If the air conditioner is running too (summer camping), you have a high chance of overloading the 30 amps.
If so, you can turn off the electric heating element (run on propane only), or turn off other high amp appliances until the electric element heats the water up and the thermostat shuts if off.
2011 Flagstaff 831 RLBSS
Ive lost my scapegoat.
Old 05-05-2015, 06:06 AM   #5
wicked1's Avatar
I don't ever switch to electric takes too long to heat up, I pressurize the water lines, make sure the pressure relief valve lets water out then I turn it on and leave it on all the time. I shut it off before leaving the campground and if I am not going back out within 10 days I will drain it, rinse it out and put more tape on the threads for next trip.
2014 Ford F-150 FX4 Crew 4X4 EB 3.5 Twin Turbo
2015 Roo 23IKSS Saphire
2015 (3) Nights Camped
2016 F350 Supercew Short Box 6.7 PowerStroke Diesel
2013 Crusader 295RST Touring Edition
wicked1 is offline   Reply With Quote
Old 05-05-2015, 07:30 AM   #6
I have never used electric, the lp is just fine. What is the reset button for on the front of the outside panel?
syogerst is offline   Reply With Quote
Old 05-05-2015, 07:51 AM   #7
KyDan's Avatar
LP costs you money plus hassle of filling tanks.
Electric is usually included in the price of a camp site.
Why not use the electric unless/until you need quicker recovery and then
you can switch on the LP??
FWIW- we leave our electric on all the time and have never tripped the
main 30A either in the trailer or on the power post.
YMMV!
Happy Trails!
Peace!
Dan & Rita D
Blue Ox WD hitch
Old 05-05-2015, 07:54 AM   #8
TURBS's Avatar
We Use electric exclusively untill shower time, then we use both for faster recovery.
Then once showers are over back to electric.
When we camp without shore power then we use propane obviously.
TURBS
08 duramax tuned n modded, 32bhok Sabre
2015 camping "4 nights"
Old 05-05-2015, 08:55 AM   #9
wicked1's Avatar
TURBS
I may try that this weekend, seems to be a reasonable way to do it 😜
Old 05-05-2015, 08:58 AM   #10
TURBS's Avatar
Seems like a fair way to do it doesn't it?
TURBS
heater, water, water heater
