Old 09-07-2015, 02:23 PM   #1
2014 233s Rockwood Roo
Water heater Anode
I have the 2013 233s Roo. It comes with the 6 gallon Suburban SW6D water heater. I pulled the anode out and it needs replaced but I can't find anywhere the part number. Anyone have this problem??
WFDEric is offline   Reply With Quote
Old 09-07-2015, 02:25 PM   #2
Sorry 2014 Roo....
Old 09-07-2015, 02:42 PM   #3
And then I found it lol...So for anyone else that has the same question is a 9 1/2 inch long 3/4 treads...232767 is the part number....
Old 09-07-2015, 02:45 PM   #4
If you do a google search with your water heater model it will bring up all the information you need, including a pdf of the owner's manual. Amazon has several, I believe the suburban owners manual specifies to use only suburban anodes so it's up to you if you get that or one of the camco anodes that has a drain petcock which makes for easier winterizing. The Suburban part number is 232767.
2015 A122S
CJofWolfcreek is offline   Reply With Quote
Old 09-07-2015, 09:24 PM   #5
i installed a brass plug in place of mine.
under_boost is offline   Reply With Quote
Old 09-07-2015, 09:26 PM   #6
Not a good plan. The anode is there for a reason.
2011 Traverse LT, 3.6L, FWD
Old 09-07-2015, 09:30 PM   #7
WFD
x2....see what those anode rods look like after a yr or 2? without the anode rod it will eat the inside of your tank.
2016 Chevy Silverado 2500 Duramax
2016 Rockwood 8289WS, Diamond Pkg.
WFD is offline   Reply With Quote
Old 09-07-2015, 09:32 PM   #8
Wrong answer! Youroo!!
Old 09-07-2015, 09:40 PM   #9
bikendan's Avatar
Bad move if it's a Suburban, which is what the OP has.
Old 09-07-2015, 09:42 PM   #10
Sacrificial Anode basics:
Hot water heater anodes and rust protection
They are called sacrificial for a reason
https://tse3.mm.bing.net/th?id=JN.Zc...FPMQg&pid=15.1
2014 Rockwood 2618W Windjammer
2014 F150 XLT S-Crew 4x4, 3.5L EB, 6.5' Box, Maxtow, 36g tank
SpaCityBulldog is offline   Reply With Quote
Old 09-07-2015, 09:59 PM   #11
Much easier to replace the anode every couple years than a water heater....and a lot cheaper.
Sirsea is offline   Reply With Quote
Old 09-10-2015, 08:14 PM   #12
well, thats good to know! i went off the advice of my dad...which wasn't good advice from the sounds. i will replace it with a rod tomorrow!
anode, heater, water, water heater
