Old 05-01-2015, 01:40 PM   #1
Water heater bypass. Roo 231kks
Does anyone know if the bypass is located in the back storage compartment? There is nothing in the water heater compartment on the trailers left side. It looks nothing like the one pictured in the instruction book, which I find pretty much useless at this point. I did find 3 valves near the water heater in the back compartment. I hope this picture helps. Should they be vertical or horizontal? Once again thanks for all the help!Click image for larger version
Name:	ImageUploadedByForest River Forums1430505629.893847.jpg
syogerst is offline   Reply With Quote
Old 05-01-2015, 02:19 PM   #2
KMP44's Avatar
Yes, the bypass is in the back storage compartment behind the false panel. The closed valve toward the bottom of the picture looks to it. The cold line is going into one side of the valve and the hot line (red) is on the other side of the valve. Its closed in the picture. The hot water outlet from the WH is the top valve, and its open. Can't the cold water inlet to the heater going in the bottom.
2022 Columbus 379MBC (Previous 2013 Rockwood Roo 23 IKSS)
2023 F-350 (Previous 2017 F250, 2005 F-150)
KMP44 is offline   Reply With Quote
Old 05-01-2015, 02:27 PM   #3
Jimandchris's Avatar
The three valves are indeed for the hwh bypass. In normal operation the two valves in the hot and cold line are open (like the one on the top). The valve between the hot and cold line is closed (like in your photo) hope that helps.
2019 Coachmen Freedom Express 281RLDSLE
2018 2500 HD Silverado
Equal-i-zer Hitch E4
Jimandchris is offline   Reply With Quote
Old 05-01-2015, 03:10 PM   #4
So what I need to know is... I'm flushing out the pink winterizer. Do I change the valves or leave them alone? How should they look when I'm all done? My old trailer didn't have this shut off. Thanks for your help. Sue
Old 05-01-2015, 03:19 PM   #5
VinceU's Avatar
Sue, normal operation would have the blue open to the tank, red heated water allowed to leave the tank and the blue/red valve (bypass) is left closed.
Old 05-01-2015, 03:20 PM   #6
TURBS's Avatar
You should flush antifreeze before un bypassing wh.
TURBS
08 duramax tuned n modded, 32bhok Sabre
2015 camping "2 nights"
Old 05-01-2015, 03:23 PM   #7
To flush out the anti freeze, the valve between the hot and cold need to be open and the other two should be closed (at a right angle to the piping it's on). We can't see the bottom valve but it looks like the top valve - hot is open, and the valve in the middle is closed. Should be three valves total.
Old 05-01-2015, 03:27 PM   #8
Perhaps this will help from another post
Old 05-01-2015, 03:29 PM   #9
Perfect, I think I finally got it! Now out to the camper with labels and a sharpie. Thanks again !!!!
Old 05-01-2015, 04:12 PM   #10
yetavon's Avatar
But by the looks of your pic the bypass is closed, and there may be pink in the tank that needs flushed. I would remove the anode rod, not a bad idea to check it anyway, and if any pink drains then flush the WH tank to.
Retired Paramedic
2020 FSX 280RT
2005 Silverado 1500 Ext cab 5.3 H.O.
2011 HD Road King
Nights camped since 2019.....all of Em...Homes a 2001 Sea Breeze 36' 5 ER
yetavon is offline   Reply With Quote
bypass, heater, roo, water, water heater
