Old 09-06-2011, 04:21 PM   #1
water pump question
I did a wonderfull thing over the weekend. When I put the battery in I decided to reverse the terminal cables. FYI. Not a good idea. It took me a while to figure it out, but I blew both 40 AMP fuses in my Roo 19. But now the water pump doesn't work. Does anyone know A: where the water pump is located in a Roo 19 and if there is an inline fuse or a reset?. I am thinking I may have popped that. I really need to know, because my next camping trip is electric only, so I REALLY need the pump to be working. Thanks.
southpaw821 is offline   Reply With Quote
Old 09-06-2011, 06:26 PM   #2
pump
some times theres a fuse at the pump. Try following the water lines back to your water fill or city water connection the pump should be close to your water tank
good luck
big john and dog is offline   Reply With Quote
Old 09-06-2011, 06:29 PM   #3
TURBS's Avatar
put a battery disconnect on your battery to prevent that from happening again .
Old 09-06-2011, 06:31 PM   #4
DAISY BOYKIN's Avatar
When you find the pump-----------
When you find the pump you will find the fuse! It is located right next to it.
Good luck
Sid, Lois & HRH MISSY Terrible 2s SHIH TZU
2011 ROCKWOOD 8285 WS
2014 F-250 KING RANCH PS/SD/6R140/BFT
DAYS CAMPED 2018 21 DAYS
DAISY BOYKIN is offline   Reply With Quote
