Old 06-29-2014, 04:22 PM   #1
Water regulator and slide question
I've read it's important to use a regulator when hooking up. Don't see one in the bag of parts so assuming its part of the trailer.
Also, I have a 21dk, the slide isn't perfectly flush, but maybe it's not supposed to be? (See pic)Click image for larger version
Name:	ImageUploadedByForest River Forums1404076913.339636.jpg
xssive is offline   Reply With Quote
Old 06-29-2014, 04:28 PM   #2
markb5900's Avatar
Normally you have to purchase a regulator.
Wally world has them for about 10 bucks.
From the pictures, it looks like you are ok. There is a rubber seal on the inside where the slide meets the wall, so it may not be perfectly plum.
Mark B
2015 32 Foot Rockwood 8289WS 5th Wheel
2017 GMC 3/4 Ton TV
markb5900 is offline   Reply With Quote
Old 06-29-2014, 04:41 PM   #3
bikendan's Avatar
water regulator is something the owner purchases, unless your dealer gave you one of the cheap "starter package" with your purchase.
usually has one of the cheaper blue plastic regulators, along with a 30-15 amp adapter, a basic sewer hose/chems and a white water hose.
Dan-Retired Firefighter/EMT
Equalizer WDH and Prodigy BC
Old 06-29-2014, 04:50 PM   #4
Thanks for the help, will add that to my shopping list.
Cheers
Old 06-29-2014, 05:41 PM   #5
Check this place out:
RV Water Filter Store: Standard Filter Canisters for Whole RV
I got my reg and hose here. You will never need another. I also replaced the filter canister with one from them. Now I can use a standard filter.
Les & Heidi Kramer
2010 GMC Sierra SLE & 2014 Shamrock 23IKSS
Cleveland, OH
cpd1343 is offline   Reply With Quote
Old 06-29-2014, 06:25 PM   #6
Also, run your slide until you hear it to start to click, then stop.
When mine gets to the end, it almost sounds like you should stop, but continue on and the back wall straightens out and then it starts to click.
gunrock is offline   Reply With Quote
slide, water
