Old 02-03-2016, 09:47 AM   #21
Originally Posted by wicked1 View Post
I called Anderson and got the 350 model, Jason told me which one and I ordered it thru a reseller they recommended. I called them also because it is based on your vehicle as well as RV, best thing is call them to find the specific model you need. They run $450.00 shipped it is a heavy box like 60#'s
2014 F150 FX4 Crew 4X4 EB
2015 Roo 23IKSS
Thanks. That would probably be the one for me also. Sounds like the trailer frame is 5-6". The 350 is good for 14K and 1.4K for tongue weight so you have room to grow.
Hemlock04 is offline   Reply With Quote
Old 02-11-2016, 10:16 PM   #22
deartruc's Avatar
Originally Posted by Drenjoey View Post
We just bought a 23WS and after looking and searching online, we went with Blue Ox SwayPro.......,I think we'll be happy with it.
X2 on the Blue Ox
2017 GMC Yukon
2018 Roo 23 ikss
deartruc is offline   Reply With Quote
Old 02-11-2016, 10:26 PM   #23
Took off a Reese and changed to an Andersen, really like the improvement and cleanliness.
Timtation is offline   Reply With Quote
Old 02-12-2016, 08:13 AM   #24
I am going to go with the Andersen. The camper is not due in for 4 more weeks and the dealer said I could keep it there as long as I want. I will order it through amazon soon. The hitch looks pretty easy to install.
Old 02-12-2016, 08:36 AM   #25
Check eBay for it. Use a dealer that allows the "make offer" option. Ask for 5-10% off the listed price.
Also use the fitment guide and/or call Andersen directly to make sure you order the correct model for your TV/TT.
Sent from my XT1254 using Tapatalk
madmaxmutt is offline   Reply With Quote
Old 02-12-2016, 10:42 AM   #26
wicked1's Avatar
It is easy just need a torque wrench that allows for 90-150 lbs
I took mine to a local school leveled it and followed the video on Anderson's site. I did call Jason from Anderson to get the right hitch. Also once it is installed don't worry if the brackets pop forward Jason said this is normal but hardly feel the trailer now and so easy to use. See my photo of the bracket below
Name:	ImageUploadedByForest River Forums1455291757.562589.jpg
2015 Roo 23IKSS
2016 F350 Supercew Short Box 6.7 PowerStroke Diesel
2013 Crusader 295RST Touring Edition
wicked1 is offline   Reply With Quote
Old 02-12-2016, 12:42 PM   #27
When installing mine I tightened the set screws down, removed them and drilled the dimple with a bit about 1/2 the screw diameter. I also found that after making the first set-up without weight then dropping the weight onto the ball I had to adjust to a different bolt hole. All in all pretty easy, good help from Jason as needed. The pop when the brackets snap forward is disconcerting until you realize what it was.
Good luck and enjoy.
hitch, weight
