Old 03-17-2012, 07:53 PM   #1
Athens-M50's Avatar
What are these...becasue I broke them...dangit!
Not sure what these are....but got the camper out today and was washing the top....and ran the brush into these.....
just not sure what they are??.....but they are broke NOW!
YES...I ran into BOTH of them!!!!!!!
2002 17' Shamrock
2001 F150 Ext Cab
________________
2012 nights camped 6
Athens-M50 is offline   Reply With Quote
Old 03-17-2012, 08:01 PM   #2
Coops1's Avatar
Looks like your sewer vent caps.
26WRB - V-Lite
Denali HD LML
Coops1 is offline   Reply With Quote
Old 03-17-2012, 08:20 PM   #3
Oakman's Avatar
Yep, holding tank vent caps.
Bob and Joyce
2013 CC Silverback 29RL
2010 Ford F250 XL Crew Cab 6.4 liter diesel
ATU Local 788
Oakman is offline   Reply With Quote
Old 03-17-2012, 08:22 PM   #4
TURBS's Avatar
There cheap to replace.
they pull right off. 4 bucks each I seen yesterday.
Old 03-18-2012, 08:04 AM   #5
MtnGuy's Avatar
Some of those caps have a screw that needs to be removed. If there is a small hole on top filled with caulk, dig into that to find the screw head.
I have already had to replace 1 of my vent caps, and my unit is only 4 years old. The sun really can do a number on those puppies.
I found vent caps and the bases at a local RV dealer for a couple dollars each. I just replaced the cap, not the base.
Old 03-18-2012, 06:32 PM   #6
Dodge Guy's Avatar
Now is the time to get a 360deg. Vent cap. Basically it is a free spinning venturi type vent that removes odors from the tanks. I only replaced my black tank cap.
02 Ford Excursion V-10 4.30 gears 5 Star Tuner Y-pipe mod Hellwig sway bar Rear Airbags
Prodigy and Dual Cam
07 Cherokee 32B
Better to have a bad day of camping than a good day at work!
Dodge Guy is offline   Reply With Quote
Old 03-18-2012, 07:59 PM   #7
Athens-M50's Avatar
these seem to be cemented in.....tried to pull it off...and it just exploded in my hand.....looks like I will have to peal the cement off and replace cap...then cement back in????......is that normal?....
2002 17' Shamrock
2001 F150 Ext Cab
________________
Old 03-18-2012, 09:32 PM   #8
showtime0022's Avatar
Might upgrade to the cyclone works good and under 20 bucks at wally mart
showtime0022 is offline   Reply With Quote
Old 03-18-2012, 09:45 PM   #9
Athens-M50's Avatar
I saw someone said that they had a screw holding it on.....these seem to be sealed with a cement.....is that normal?
2002 17' Shamrock
2001 F150 Ext Cab
________________
Old 03-20-2012, 07:41 AM   #10
Athens-M50's Avatar
$26.95 fixed 2 roof vents...DONE! :-)
vents were only about 6 bucks.....the rest was caulk and sealant tape :-0
2002 17' Shamrock
2001 F150 Ext Cab
________________
expandable, hybrid, shamrock
