Old 08-13-2015, 07:57 AM   #21
Pockets
My TV is on a hanging wall bracket. I looked at the back of the TV to see if there was hangers for that outside bracket and couldn't see any. And removing the TV from the wall bracket looks like a major effort. Am I missing something? Dudleydoo and KC, are your TVs on a wall mount that pulls out about 9 inches and if so, how do you take the TV off easily?
Bob & Kelley
2015 Flagstaff 26RBSS
2014 FORD F-150 Supercrew XTR 4x4
3.5L Ecoboost, 3:73 axle, Max Tow Pkg 2015(36 nights) 2016(74 nights) 2017(174 nights) 2018(157 nights) 2019(79 nights) 2020(108 nights)
Pockets is offline   Reply With Quote
Old 08-13-2015, 08:11 AM   #22
nomad297's Avatar
I have a 42" TV mounted outside on my Windjammer wherever I want it mounted. I also have a dedicated DirecTv receiver for this TV stashed inside of a compartment. Here is the mount I use:
GOstik Products Flat screen TV Suction Cup Mount | GoStik
It's not cheap, but it really is the perfect solution for me. It will hold the weight and it will attach wherever I want it.
Bruce
Old 08-13-2015, 08:14 AM   #23
ROCAMPER's Avatar
The bracket on my 23ss lifts up from the attachment point at the wall.
ROCAMPER is offline   Reply With Quote
Old 08-13-2015, 08:17 AM   #24
RooVader's Avatar
It is much easier to pull out and put back if you extend it out. At first it seems like it would be difficult but it really does come out and go back in very easily.
XLR 24HFS -> Roo 21DK -> RPod 183g
2013 F150 FX4 EB
RooVader is offline   Reply With Quote
Old 08-13-2015, 08:38 AM   #25
Is that outside cable hook-up for when you have park cable available or does it feed from the antenna?
Also, anyone know where to order an additional TV bracket so I could hang a second TV outside without disturbing the inside TV?
2015 Shamrock 23IKSS, Oyster shell
2019 Chev Silverado LT Z71 Ext. Cab, 4x4, 5.3L V/8
Reese Straight Line WDH, 2000W Honda Gen.
2 Old Town kayaks & 2 Boston Terriers - Zoey/Gonzo
Lar & Ruth
CNYCamper is offline   Reply With Quote
Old 08-13-2015, 08:48 AM   #26
RooVader's Avatar
Antenna. There is a thread in here that has the link to the brackets, pretty recent one. For the life of me I am not finding it.
2013 F150 FX4 EB
Old 08-13-2015, 08:57 AM   #27
Thanks RooVader! Glad its for the antenna since I've never been in a park with actual cable available. I'll look for the bracket thread. Thought it would be cool to mount a TV outside for when the 3 yr. old grandson visits so he can see what a drive-in was like.
Lar & Ruth
Old 08-13-2015, 09:15 AM   #28
urocav2001's Avatar
What are these for?
Wish they would have installed a hdmi jack too to watch the DVDs from the DVD player that's inside
urocav2001 is offline   Reply With Quote
Old 08-13-2015, 10:37 AM   #29
nomad297's Avatar
The hookup should work for both cable and antenna.
You can have your dealer order another TV bracket from Forest River.
Bruce
Old 08-14-2015, 04:58 AM   #30
Oaklevel's Avatar
Hopefully here is a picture of our outside inside and tV mounts. It seemed hard to get off the first time as I did not know what to expect.
ID:	85616   Click image for larger version
ID:	85617   Click image for larger version
2005 Dodge 3500 Cummins
2017 Wildwood Lodge 4092 BFL
1966 Mustang GT
1986 Mustang SVO
Old 08-14-2015, 05:04 AM   #31
Oaklevel's Avatar
Try dealer or some of these seem the same mounts ramco-eng.com .
Our Puma came with two different mounts .
1966 Mustang GT
1986 Mustang SVO
Old 08-14-2015, 05:11 AM   #32
Pockets
Thanks Oaklevel. I'm camping this afternoon and will look that my inside connection looks like yours. If it does then it would be compatible with the outside bracket. My outside bracket looks more like the originator of this thread's picture
Bob & Kelley
Old 08-14-2015, 07:32 AM   #33
RedStick's Avatar
I'm a directv subscriber. What I do is bring a receiver from home, and hook that up inside the Roo.
I've got two Hdmi cables - one for inside use, and one that is 30' for outside use.
Instead of having to bring the tv and receiver outside, all I have to do is remove the tv and unplug the shorter Hdmi, etc.
The 30' Hdmi cable runs from my 23ss "tv area" out the door and down the side of the Roo, over the door inside and out the dinette window, or I run it through my front tent end of the Roo and then to the outside tv (the best option in my opinion).
Works for me.
2013 Rockwood Roo 23ss
2012 F150 Ecoboost
Camped for 12 nights in 2015 - too many cancellations
Camped for 25 nights in 2014!
Camped for 24 nights in 2013!
RedStick is offline   Reply With Quote
Old 08-14-2015, 07:36 AM   #34
dudleydoo's Avatar
Bob and Kelly,
The TV does pull out from the wall a bit but I have not looked behind it yet. Since I didn't know that gizmo was for holding the TV I didn't think about removing it from. I'll have to go out there today and check this out.
I'm not sure about watching TV outside. It might be okay as long as I don't disturb other campers.
I never thought about having it outside to show the grandkids what an "outdoor" movie theater was like.....good one.
Bonnie and Rich
Oconomowoc
Winston (Rat Terrier)
Digby (Lhasa Apso)
2014 Shamrock 23IKSS
dudleydoo is offline   Reply With Quote
Old 08-15-2015, 02:15 PM   #35
The bracket can also, especially in pairs, be used to hold an outdoor grill on certain models. Our RV had 3 brackets, two to use as a pair for an outdoor grill and one by itself for the TV. I have a friend who had an aluminum framed trailer and he installed additional brackets being sure to tap into one of the metal studs. He used s silicone adhesive to seal the screw holes and used expanding wall anchors for drywall to hold the weight of a larger, stainless steel grill he uses outside. He uses a 5 gal propane tank and regulator to supply the grill. He claims it works well. I have no experience.
MacII is offline   Reply With Quote
Old 08-16-2015, 03:13 PM   #36
Pockets
You were right. The TV wall bracket has the same mount on the wall as it does on my kitchen slide. Just unplug the tv, cable, hdmi and audio jacks and it is free. Will find a suitable cable in my basement to put in the trailer just in case I want to watch it outside. Will not be able to use the outside speakers because the TV will not be hooked up to the entertainment unit through the RCA jacks.
Bob & Kelley
Old 09-02-2015, 08:48 PM   #37
I have a 233s. I was also sad there was not an hdmi hook up outside. There is an easy fix:
You need a twenty foot hdmi cable. Disconnect the stereo and pull it out. Remove the microwave. Connect the 20ft hdmi cable to an extra hdmi out connection in the back of the stereo. Fish the cable behind the microwave and down the side of the pantry. You will see lots of wires behind the microwave running down the false cavity on the side of the pantry. Remove the false back of the lower pantry cabinet. You will see the outside opening for the lp gas line for the grill. Run the hdmi through that
Now when the tv is outside open lp gas hatch and your hdmi will be waiting for you with 5 extra feet of extension to connect to the tv.
This is for the 233s layout but if you have the lp gas outlet near the tv there should be a way to get an hdmi from the stereo to that opening.
Dav015 is offline   Reply With Quote
Old 09-02-2015, 08:52 PM   #38
What could go wrong.
Sorry
mike.t is offline   Reply With Quote
