Old 10-23-2015, 02:02 PM   #1
What are you using to pull your 23IKSS?
I am thinking about upgrading to a 23IKSS and was considering the Chevy 2500HD as a tow vehicle but it seems that a lot of them are being towed by 1/2 ton pickups. What are you using to tow your 23IKSS? If you are using a 1/2 ton are you using LT tires?
2015 Rockwood Roo 23IKSS
2015 GMC Sierra 1500
Archicamper is offline   Reply With Quote
Old 10-23-2015, 02:27 PM   #2
bikendan's Avatar
You don't "need" a 3/4 ton truck to tow a 23IKSS.
My 23SS is similar in length and weight and I tow it with a 1/2 ton Avalanche that has P tires.
The only reasons to get a 3/4 ton TV, is you see yourself going bigger in the future or you want more than enough towing ability.
Dan-Retired Firefighter/EMT
Equalizer WDH and Prodigy BC
Old 10-23-2015, 03:19 PM   #3
Ours tows with absolutely no issues including many trips within the Adirondacks. Gear is a 3.42 and tires are P (Goodyear Wranglers). When we both retired we downsized to one vehicle so this is also our daily driver.
2015 Shamrock 231KSS, Oyster shell
2016 Chev Silverado LT Z71 Ext. Cab, 4x4, 5.3L V/8
Reese Straight Line WDH, 2000W Honda Gen.
2 Old Town kayaks & 2 Boston Terriers - Zoey/Gonzo
Lar & Ruth
55 nights camping 2015, 45 in 2016, 42 in 2017
CNYCamper is offline   Reply With Quote
Old 10-23-2015, 06:22 PM   #4
2013 Ram 1500. 5.7 hemi.....more than enough power and brake for a 5000 lb dry camper. P tires also. Got about 30000 on the tires so talked to a friend who owns an independent tire store. He suggested staying with p tires because the tradeoff in ride harshness wouldn't be worth it. I personally have never felt unsafe with the stock Goodyears but I will upgrade to Bridgestones when I get tires next year. Get a good wdh and a half ton will be fine ( unless there is that possibility of a much bigger unit in the future).
Jim and Deb
Many times..asst grandkids
2015 Shamrock 23ikss
2013 Ram 1500
jking46 is offline   Reply With Quote
Old 10-23-2015, 06:40 PM   #5
Any 1/2 ton will pull the 23ikss just fine. 3/4 is an overkill unless you plan to pull a bigger trailer in the future. These are lightweight trailers built to be pulled by smaller vehicles. I use a Ram 1500 Ecodiesel with LT tires and it pulls effortlessly. Good luck in your search.
Mikewcrook is offline   Reply With Quote
Old 10-23-2015, 06:53 PM   #6
DK-in-SC's Avatar
We pull our 23IKSS with a 2008 Ford Expedition EL. Works great.
I live with fear every day, and sometimes she lets me go fishing.
2015 Shamrock 23IKSS
DH-DW-D3K-DMTTSAP
DK-in-SC is offline   Reply With Quote
Old 10-23-2015, 06:57 PM   #7
Georgia Frog Rally 2018
aceinspp's Avatar
Last time I looked it was a truck Later RJD
2015 Chevy 2500 6.0 4:10 gearing.
Days camped in 2016 58
Days camped 2017 62
Days camped 2018 18
Old 10-23-2015, 09:37 PM   #8
I pull my 23IKSS with a 2014 Toyota Tundra 5.7 litre with 3.93 gear no problems and get btwn 9-11 mpg.
JWHybrid2B is offline   Reply With Quote
Old 10-24-2015, 11:52 AM   #9
Tundra with 3.93 gears...? I thought they all had 4.30 gears ?
danc is offline   Reply With Quote
Old 10-24-2015, 12:08 PM   #10
2014 Land Rover LR4 with a supercharged V6 (332 ft/lbs of torque @ 3500 RPM) mated to an 8-speed transmission which does a reasonably good job of keeping the RPM in the proper range with minimal hunting. That said, when there is a lot of variation in the grade I shift manually - both uphill and downhill when I want to use engine compression to save the brakes. I also have low range should I need it. The LR4 is a 7K lbs vehicle. Works great even in the mountains of Colorado but I am a patient driver. I keep to the right lane most of the time - especially when climbing steep grades. I added a Hensley sway-elimination and weight distribution hitch and installed an aftermarket (Curt) hitch receiver rated for 8,000 lbs and 800 lbs tongue weight just to be safe.
ID:	92736   Click image for larger version
drhroo is offline   Reply With Quote
