Old 08-20-2015, 04:24 PM   #1
2016 Shamrock 183 Hybrid
What is that shelf material?
Our Shamrock 183 came with a grill and a black shelf that can be hung on the Patrick Metals 164922** sliding table support mounted outside. **Some kind fellow from the forum told me this was the proper name of that extruded aluminum. The shelf is constructed of some form of solid weatherproof black plastic. It measures about 18" x 10" x 3/4" thickness.
I would like to purchase a larger piece of this weatherproof solid plastic to make a shelf of about 30" x 48" x 3/4 thickness, but do not know what to use as a search term. Does anyone have an idea of what this material is?
Basically, it can be drilled and will hold screws to attach a Patrick Metals bracket. Due to the size, I would fabricate one or two foldup legs to support the front edge. Just need a name.
sparty047 is offline   Reply With Quote
Old 08-20-2015, 04:55 PM   #2
Search plastic cutting boards on google if they are not exact they are very close.
2016 Flagstaff 23lb
Toddupton is offline   Reply With Quote
Old 08-22-2015, 08:40 AM   #3
Thunderbolt75's Avatar
It's probably a product similar to "Starboard". It's a ultra high density polyurethane.
It's available in sheets and partial sheets on eBay and Amazon. Local marine suppliers also stock it in South Jersey.
2016 Surveyor 191T
2006 KZ 37KGx2
2005 Dodge 3500 4x4 CTD 325/610
Be safe, but if you cannot, be violent.
Choose to be a winner, not a victim.
Thunderbolt75 is offline   Reply With Quote
