Old 05-10-2012, 07:06 PM   #11
Quick search came up with this:
I quickly found that Eternabond is removable, but not necessary all the time.
From the Eternabond website:
Removing EternaBond®
How do you remove the best sealing tape in the world? Well, it is not easy, but if you follow these instructions, it is not impossible.
First, you have to determine if you really need to remove it at all. For example: if you are going to replace a skylight or vent that has been sealed with EternaBond®, and after replacing the skylight or vent are going to reseal it with EternaBond®, you can simply:
  1. Cut through the old EternaBond® tape along the edge of the old skylight or vent.
  2. Remove the screws holding it down.
  3. When you lift the old skylight or vent off, half of the EternaBond® will be on the flange of the skylight or vent, and half will still be on the roof.
  4. When you install the new skylight or vent, simply screw it down and?
  5. Put a new piece of EternaBond® over the first in the same place.
OR?
Second, if you have determined the EternaBond® must be removed, follow these instructions:
  1. Using a heat gun or a hair drier, heat up 2-4" of the tape on one end.
  2. Grab a corner of the tape and pull on it. The sealant should stretch like pizza cheese.
  3. As you are pulling on the tape, cut the stretched EternaBond® with a razor blade, keeping it wet with water.
  4. At this point some of the residual gray EternaBond® MicroSealant® will still be on the roof. Work it off using a strong solvent like lacquer thinner, acetone, or gasoline, and some elbow grease, or...
  5. Leave the residue in place. It will not hurt anything, and if you put new EternaBond® over the old, the new MicroSealant® will absorb the old MicroSealant®
James
2005 Excursion Limited dragging a 2012 Roo 233s
DSN46 is offline   Reply With Quote
Old 05-10-2012, 07:15 PM   #12
Herk7769's Avatar
DSN46 is exactly correct.
Prepping the roof for EB does not require removal of the old Dicor. You just spray on the EB primer and wipe with a white lint-less cloth (Box O Rags type). The Dicor should become "sticky" and the EB will grab like a ... well a lot.
To LAP EB tape, wipe the white surface of the tape on the roof with EB primer on said rag, and slap the lapped tape right on top.
I would definitely touch up any cracks or holes with fresh Dicor before I EB'ed over top of it. Cheap insurance.
Name:	913th 3rd Annual Picnic and Camper photos 035.jpg
ID:	13557   Click image for larger version
Name:	913th 3rd Annual Picnic and Camper photos 036.jpg
HAM CALLSIGN - KC3FFW
