Old 07-11-2016, 12:10 AM   #11
Sky&Scuba
kendive's Avatar
Equal-i-zer Snap-Up Lever 1/clamshell
2015 F150 3.5 EcoBoost Lariat FX4 502A 3.55 Gears Max Tow KO2 Tires
2017 Grand Design Imagine 2150 RB / Traded in Catalina 253RKS
kendive is offline   Reply With Quote
Old 07-11-2016, 12:32 AM   #12
qwkzotc's Avatar
good caution
robbdrell has a good point. The best way to put on the equalizer bars and to take them off is with the trailer lifting the truck to the highest possible point with the nose jack. This takes all of the tension off of the WDH. Many have reported serious injuries when trying to use this tool to release the tension bars while the truck and trailer are in a level position. Hopefully you also have wire safety loops to run the tension bars through to catch them if they should release too fast and fly out while unhooking them. Your truck and trailer should also be in straight alignment, even if you have to pull out to a staging area before installing/removing the tension bars. This reduces the need to use this tool as well.
Dan
2014 Palomino Puma 19RL
2012 Toyota Tacoma with TRD SC
Husky Centerline WDH
Firestone Ride Rite Airbags
Winegard G2 Portable Satellite
qwkzotc is offline   Reply With Quote
Old 07-11-2016, 01:12 AM   #13
Originally Posted by qwkzotc View Post
robbdrell has a good point. The best way to put on the equalizer bars and to take them off is with the trailer lifting the truck to the highest possible point with the nose jack. This takes all of the tension off of the WDH. Many have reported serious injuries when trying to use this tool without reading and following the instructions.
Dan
Fixed that for ya!
2008 Toyota Sequoia SR5 5.7L 10k tow package
2017 Rockwood 2702WS
Equal-i-zer 4 point, Prodigy 3 brake controller
2016 nights camped = 11
Chpusmc is offline   Reply With Quote
Old 07-11-2016, 04:58 PM   #14
Originally Posted by robbdrell View Post
That's for the Equalizer system but I never use it. If I lift up my truck high enough with the tongue jack, the bars will be high enough to slide over the attachment so I can insert the pins.
X2
2015 GMC Sierra 1500
2013 Heartland North Trail 28BRS
spudston is offline   Reply With Quote
Old 07-11-2016, 08:12 PM   #15
wbdavey's Avatar
I painted my SECOND spring bar tool bright fluorescent orange so it doesn't get left on the truck bumper and end up in the ditch somewhere with the first one.
2015 Rockwood Ultra Lite 2604 WS. Rear LR, large street side slide with small wardrobe slide in BR.
2014 Ram 1500 Eco Diesel Laramie Quad Cab.
wbdavey is offline   Reply With Quote
Old 07-11-2016, 09:31 PM   #16
Four years, I've never had to use mine.
1988 Coleman Sequoia - popup (1987-2009)
2012 Roo19 - hybid (2012-2015)
2011 Traverse LT, 3.6L, FWD
2009 Silverado Ext Cab, 5.3L, 4x4, 3.73
Old 07-11-2016, 10:42 PM   #17
Old Eeyore's Avatar
Used ours a couple of times when we couldn't get quite enough lift to take all of the tension off - usually just one of the bars.
Caution should be used no matter how short the distance - that puppy can pack a punch.
2016 Roo 23IKSS / 2011 Tahoe
2011 Roo 21SS / 2011 Tahoe
2006 Bayside / 2006 4Runner
1999 SantaFe / 2001 Sienna
1967 Nimrod / 1998 Outback
Old Eeyore is offline   Reply With Quote
Old 07-17-2016, 12:09 PM   #18
Summer2Go
Summer2Go's Avatar
Jacking the hitch up, and parking "in-line", I never need this tool. I will be in trouble if I need to swing the bars in or out, mine won't budge for me.
Summer2Go is offline   Reply With Quote
Old 07-17-2016, 12:26 PM   #19
Occasional campers
Jacking the hitch up is a huge help, but I've found that (particularly for off-level locations) it isn't always enough and the stress can make me a little nervous. The tool is invaluable for not having to max out the physical strain; it's designed to give the right leverage. I also keep a crowbar as additional backup.
Ray and Ann is offline   Reply With Quote
