Old 09-21-2015, 03:00 PM   #121
oldgold's Avatar
Originally Posted by MOODMAN View Post
Seeing as this thread is discussing noise, has anyone tried running one of those long pipes from the exhaust out the top? If so, does it stop or greatly reduce the noise?
I'm assuming you're asking about an onboard.
It seems to help greatly with heat and gas looming under the trailer. Also it keeps the hot exhaust away from the air intake.
As far as noise goes... Not really... If I put on all 3 pipe stacks ours actually makes a harmonic noise inside the TH, if I just use 2 pipes there is no additional whining noise.
2015 XLR Nitro 30FQSL
2015 F250 King Ranch
oldgold is offline   Reply With Quote
Old 09-21-2015, 07:03 PM   #122
If I are looking at champion generators, check out cabelas deer camp sale. That coupled with those coupons they love to send u can get these for very cheap prices
Mountndream is offline   Reply With Quote
Old 09-22-2015, 09:42 AM   #123
I have the Champion 3100 Inverted. Works like a champ and cost 1/3 what I would need for a Honda or Yamaha. I've only had it for 8 months, but has been great. Its only slightly louder than the Hondas, but its not bad.
2013] Rockwood 2503s
2014 Jeep Grand Cherokee HEMI V8 w/tow package
Nights Camped this year: 2
Nights Camped last year: 39
chuckythe2651 is offline   Reply With Quote
Old 09-25-2015, 11:12 PM   #124
Blackhat6mike's Avatar
I would be very careful with exhaust fumes coming into the roof vents if they are left open.
I installed a wind vane type of vent on top of my unit and if the wind passes over the vent and the roof vents are down wind, it will run you out of the unit!! I chased that smell for many hours before I figured it out. I'm sure exhaust would do the same. Be careful!
Aviator Wright Flyer #1919
Army Pathfinder Vietnam, 3 tours
DAV, MOPH, VFW, NRA, 1stCav. ABN
Blackhat6mike is offline   Reply With Quote
Old 09-26-2015, 09:33 AM   #125
Originally Posted by Blackhat6mike View Post
.... I'm sure exhaust would do the same. Be careful!
You are so right. I hadn't thought of that, but it could even be deadly with CO at night.
In fact, building codes mandate that exhausts above rooflines be a certain height above the ridgeline so that just that thing doesn't happen to houses.
MOODMAN is offline   Reply With Quote
generator
« Tires | HD Antenna »
