Old 05-10-2012, 07:05 AM   #1
Triguy's Avatar
My early 2012 has a Genesis 2.0 and it's in the shop for a third round of diagnostics (B&C speaker issues). I'm kind of curious if it's the speakers, wiring or radio or all three.
I'll let you know, but I'm wondering what radio is in the new Roo/Shamrocks people are getting this year?
Scott
DW, 3 Kids and our Goldens
2012 Shamrock 233S
2008 Toyota Sequoia 5.7L 4WD
Old 05-10-2012, 07:11 AM   #2
Mad4sax's Avatar
I ordered a 2013 Shamrock 233S in April and asked FR the same question here is the reply.
Gregg Rollins <grollins@forestriverinc.com> wrote:
GT-2 STANDARD RADIO
Mad4sax is offline   Reply With Quote
Old 05-16-2012, 10:06 PM   #3
Kaytee1206's Avatar
Ours is a Genesis.
2013 Rockwood Roo 25RS
Kaytee1206 is offline   Reply With Quote
Old 05-16-2012, 10:31 PM   #4
Triguy's Avatar
Thanks Mad4sax and KKapa.
The one and only persistent problem with my trailer is the radio. It's in now and they're replacing it again. I wanted to see what I'd get.
Scott
2012 Shamrock 233S
Old 05-17-2012, 08:27 AM   #5
cogito ergo moo
Cowracer's Avatar
My radio had one speaker not working out of the factory. A pin came out of the Molex connector on the back (on the trailer side of the connector, not on the radio side). A molex connector is set of plastic shells, with metal "pins" that snap into the shell. There are male and female pins, and a male and female housing.. The pins are crimped onto the wire, and pushed into the shell from the back side. There is a small barb on the outer edge of the pin to hold it in the shell. Otherwise the action of clipping the two halves together will push the pins out the back side of the plastic housing.
Heres a good picture of a molex connector for a computer. You can clearly see the male and female pins.
I snapped my loose pin back in, and checked the other. I found 2 more that were not properly set into the shell. All 3 were on the FR side. I am led to belive that someone in FR is not installing the pins correctly, and the connections are coming apart some time after shipping. I wonder how many stereo problems can be tracked back to this...
A very simple fix is to remove the radio, separate the two halves of the connector, and try (gently) to pull the wires out the back of the connector shells. You shouldnt be able to remove the wires/pins. If they come out, they were not installed properly.
This is what the pins look like when removed.
You can barely make out the small barb near the middle that locks the pin in the shell. You might have to gently pry the barb out a touch so it properly locks into the shell. then simply push the wire/pin back into the connector from the back side. You can do this with your hands, or with a small pair if needle nose pliers on the wire. Give it a tug when youre done to make sure its seated
I would look at this connector before I went through all the trouble of turning it in for warranty.
tim
FROG Member MO-0008-571 Since 20124444444444My Project Blog: https://cowracer.blogspot.com/
2016
Rockwood Signature Ultralite 8329ss
Rallies Attended:
Cowracer is offline   Reply With Quote
Old 05-17-2012, 09:56 AM   #6
Triguy's Avatar
That's a good illustration you wrote up there Cowracer.
I thought of that, too. The second unit they put in the trailer had a problem with the B & C speakers - they worked intermittently and when they didn't work, it was either nothing, a hum or a steady snap and pop.
I had two wiring harnesses and checked both for loose connections liked what you did so well describing above.
I also checked the connectors for the speaker that I could reach. No luck in my case.
So, I took it in for that and a ripped cushion for warranty work. I'll pick it up tomorrow and talk with the tech and see what he found. All I know right now is that he thinks its the actual Genesis 2.0 that needed to be replaced.
Scott
2012 Shamrock 233S
