Old 07-11-2015, 02:35 PM   #31
Love RVing
Your wife thinks like mine, smarter than me. Maybe 4 extra 6 volt batteries would help.
burse is offline   Reply With Quote
Old 07-11-2015, 03:28 PM   #32
B and B's Avatar
Originally Posted by youroo View Post
Buy a (Ford or Dodge) Diesel Truck and charge your RV Batt. That should Really bring some Response from the (Quite Police)! Youroo!!
Last time i listened the 2015 GMC Duramax next too me it was noisier...
2017 Heartland Bighorn 3575 Elite with Reese Sidewinder
2016 Ford F 350 SD PS 6.7 SRW Crew Pucks and Reese 18 K Elite
2013 Rockwood 8289WS 2012 Rockwood 2703 SS TT 2007 Golden Falcon 38FLA PM 1983 Corsair 21RB
2015 Ford F250 PS '13 F150 3.5 Eco '09 F150 5.4 l 1987 Merc Grand Marq 1982 Ford E250 CW
B and B is online now   Reply With Quote
Old 07-11-2015, 03:50 PM   #33
True but your Ford was NOT running! Youroo!!
Old 07-11-2015, 04:08 PM   #34
Georgia Frog Rally 2018
aceinspp's Avatar
I'd find another camp ground. Rules where made for a reason tying to sharp shoot the system will tend to up set the folks that abide by the rules. Later RJD
2015 Chevy 2500 6.0 4:10 gearing.
Days camped in 2016 58
Days camped 2017 62
Days camped 2018 18
Old 07-11-2015, 04:19 PM   #35
pkenley's Avatar
6x4
Didn't think I was going to see a suggestion like my solution until "burse" got close. This worked extremely well for us. (However if wife is having $$ issues with your "more stuff" this may not work for you.)
I replaced the two 12 volts with two 6 volts in series and then put 2 more 6 volts in the plastic box in the back of my truck and wired them with a switch and plugs so I can either run them in parallel or choose to run on either bank. Give me a lot of amps.
I have always run off one bank at a time therefore I switch to fresh bank and top off the bank I used the previous day with my generator.
I think I'm going to try plugging my battery charger into the built in inverter in my truck to recharge a bank next time I dry camping.
Phil & Carla Kenley
2014 Rockwood ROO 21ss
2013 Ford 150 Platinum Crew Cab
(Looking at the Georgetown 329DS)
Nights camped in 2011/16; 2012/15; 2013/48;
2014/10; 2015/101 2016/55 yr to date
pkenley is offline   Reply With Quote
Old 07-11-2015, 04:51 PM   #36
(Dry Huunday)
DreiHunde's Avatar
Heck. I'm liking the sound (or lack of) this place!
Beau & Sue
FurKid Express
2015 Coachmen Catalina 303RLS
DreiHunde is offline   Reply With Quote
Old 07-11-2015, 04:53 PM   #37
Solar
Solar panels are cheap, and hidden out of site on the roof. I have two that are at least ten years old and have gone through three RVs. This far too simple a solution to struggle with it.
If you actually have too much stuff, get rid of some of that stuff and put up solar panels. I almost NEVER run a gen set anymore.
hankpac is offline   Reply With Quote
Old 07-11-2015, 04:58 PM   #38
camaraderie's Avatar
If you presently have the standard pair of group24 batteries you have 75 amp hours to work with before you need to recharge...you might push it to 100 in a pinch. 100 amp hours @ 12 volts gives you 1200 watt hours... spread over 7 days or 170 watt hours a day to power everything.
Example...if you have a pair of 25watt conventional light bulbs on for an hour...that is 50 of your watt hours used.
Obviously, people have been tent camping with propane stoves an flashlights etc. ...so you CAN exist on your existing batteries for a week...but it is gonna be really rustic!
NONE of the suggestions for charging your batteries make a lot of sense to me. Putting 100 amp hours back into your batteries can be done at 40 amps max and will take at least 4 hours to do so. Doing it with a 20 amp charger will take 6-8 hours. More with a smaller charger. So you won't be doing much if you try to charge your batteries at a remote place.
Solar panels BTW will AVERAGE about 1/4 of their watt rating in daily amp hours provided. So a 100 W panel in a sunny mid latitude climate will give you roughly 25 amp hours daily. Not much.
If your home or a friends is reasonably close...I'd buy an extra set of batts and keep them on the charger...then make a run home and swap em out as you need to.
Otherwise the choices are:
1. Camp like trappist monks and pretend the RV is a tent in the wilderness.
2. Don't go.
Good luck...what a stupid rule that is during the daytime. Hope it works out for you.
________
Cam
2015 Georgetown 280DS
2014 Vespa LX150 2014 StellaAuto 125
camaraderie is offline   Reply With Quote
Old 07-11-2015, 05:17 PM   #39
Cypressloser's Avatar
Location: Alberta - East of the Rockies, West of the Rest
Lots of good suggestions, solar would be a longs term solution but not something you want to get into on the spot - we love ours
IMHO, the best approach would be to buy 1 (better 2) true deep cycle batteries and make sure all your batteries are completely charged before you leave and bee very conservative with your power usage, incl. fridge - also don't use old and new or different type/size batteries simultaneously.
Maybe ask the campground host if they let you charge batteries at their office or shop - you never know.
And start planing for a solar setup down the road.
Almighty 2018 RAM 5500 Laramie CC
Riverstone Legacy 38RE, 960 Watt Solar, 6x6 Volt Battery Bank, Freedom SW 3012 Inv/Charger
Cypressloser is online now   Reply With Quote
Old 07-11-2015, 05:21 PM   #40
Anacortesians
It must be a spectacular park for users to put up with that kind of harassment. For me, no power pedestal, I don't go there!
Frank and Eileen
No longer RVers or FR owners
generator
