07-10-2015, 08:20 PM
What to do, no generator allowed!
The first week of August we will be camping for the entire week, at Peninsula State Park in Door county Wisconsin. I was told last weekend at a different state park by a camper there that at Peninsula you absolutely can not have a generator! Well i have 2 12 volt batteries, but they will not last a week. So i don't know what to do! I wanted to buy a solar suitcase set up, but my wife says we have enough stuff! She said i should just take my 2000 watt Yamaha along and take the batteries off, put them in the truck and drive to town and charge them. Well that does not sound like a vacation to me! I thought about just hooking up the trailer plug and run the truck, but that could take awhile, and does not sound like a good option either! Any suggestions?
07-10-2015, 08:31 PM
Solar would have been the answer, but it's late in the game for that. Most people don't go to solar until they have no other options. When they find out how good solar works, they expand their systems and never look back.
You don't need a "suitcase", just mount them on the roof and forget about them.
If DW thinks removing the bats and taking them to town would be a good idea, perhaps you should let her, after all it WAS her idea! LOL Good Luck!
Aviator Wright Flyer #1919
Army Pathfinder Vietnam, 3 tours
DAV, MOPH, VFW, NRA, 1stCav. ABN
07-10-2015, 08:36 PM
My 2 cents. No where near familiar with that area..but, if you're going to drive to town, what about bringing a battery charger and plugging in? I think you'd charge faster than off your gen. (We've plugged the battery charger in at the bath house at the state cg we go to). (I've even been bold enough to run a 100ft extension cord when we were backed up to one of the bath houses).
2017 GMC Yukon
2018 Roo 23 ikss
07-10-2015, 08:39 PM
Cyber Phrenologist
Rig up some jumper cables and charge them with the truck. Will not take long, the truck alternator puts out a lot of current.
KU4OJ
2008 (or is it 2009?) Rockwood 8280SS - 2022 F-250 7.3L
07-10-2015, 08:42 PM
Hook up jumper cables to your TV and TT and run for 30 min apiece. It is using what you already have and gives you a reason to drink an adult beverage or two while it happens.
Just glad to get away
07-10-2015, 08:47 PM
Their rules indicate no generator but can be over ruled by area managers. But the rules specifically say people with electrical requirements due to medical issues are encouraged to take sites with electrical power hookups and may use a generator in the event of a power failure. This is the rule for all Wisconsin State parks so I doubt they will let you use it. It's all about keeping it quiet for other campers. They will put the brakes on any noise they do not consider needed for the enjoyment of camping.
Dale & Terri, Lulu & Tiki (our Chihuahua's), New rescue puppy Prince - Pom/Pug mix.
2013 Tundra, Double Cab, 5.7, TRD Off-Road, 4X4, Full Tow Package
2013 Wildwood T26TBSS - Sold
2000 Gulf Stream Sun Voyager M-8357 MH, Ford Trident V10 Gasser, 35 foot.
07-10-2015, 08:51 PM
Your information is second hand. I'd call the park to find out if the no generator rule is a fact. Maybe the park bans open frame contractor models only but allows the relatively quiet Hondas and Yamahas.
2015 Shamrock 23IKSS, Oyster shell
2019 Chev Silverado LT Z71 Ext. Cab, 4x4, 5.3L V/8
Reese Straight Line WDH, 2000W Honda Gen.
2 Old Town kayaks & 2 Boston Terriers - Zoey/Gonzo
Lar & Ruth
07-10-2015, 08:56 PM
Nope, i did call and confirmed that, only if you have documented medical need.
07-10-2015, 08:57 PM
One other thing I've seen is where when an ADA site was vacant, people would use their battery chargers there.
A TV would have a 65 amp alternator standard, 85 amp with a tow package. At idle, it will barely be putting out any more than what the TV needs. You get that amperage basically at highway RPM's. Or, jumper cables to a second battery never worked for me in the past.
2017 GMC Yukon
2018 Roo 23 ikss
07-10-2015, 08:58 PM
Thanks, not a bad idea, i like your boldness!
07-10-2015, 09:00 PM
We've gone 5 nights on 2 12v batteries several times. Are you sure you have a problem??
Peace!
Dan & Rita D
07-10-2015, 09:02 PM
Peninsula S/P is a 24 hr (Quiet Park) good luck with that! 1/3 of the Campsites have (Elect.) did you ask when you booked? Let us know about their (24hr Quite Policy)! Youroo!!
07-10-2015, 09:09 PM
Solar is a great idea. We have used the Jumper cable thing to charge our batteries and they charged quickly. Solar sounds like a better setup for dry camping!
07-10-2015, 09:12 PM
Well we have to go 7, and i dont think they are the best batteries as far as available amp hours.
07-10-2015, 09:45 PM
You can purchase a 140W panel and a controller for about $500. For this trip you can just prop it up on a PVC stand facing the sun and wire it directly to the batteries. As you have time you can make it a more permanent installation.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
07-10-2015, 10:19 PM
Rented a unit and had a half charged battery. Unit was dead just after midnight from running heater. Hooked up jumper cables and let it run (took cat nap inside TV) for 30 minutes. Charged enough to get thru til morning. Then ran for hour at 1500 rpm and was fine until next day. Worked for me- and even with that experience we went out and bought a TT.
07-10-2015, 10:31 PM
Left Coast
use an inverter at tv and a battery charger
07-11-2015, 05:47 AM
Thanks that is one option i was considering, But to make it simpler, i was thinking of using the TT power cord and plug into the inverter just like i would plug in the wall socket at home. Then also plug in the trailer plug to the back of the truck and charge both ways. Dont know if i would gain anything that way. This is the inverter i was looking at. http://www.amazon.com/BESTEK%C2%AE-O...bxgy_86_text_y
07-11-2015, 06:26 AM
I would find another campground. Doesn't sound like a place I want to go to.
07-11-2015, 06:35 AM
Yea i agree, but there is a whole group of Friends going, like 10 of us, plus some guests. So i have to go! But NEVER again. I don't know what the big deal about running a 200 watt Yamaha, that is super quiet around noon is!
