Old 09-27-2015, 01:54 PM   #1
Marine3038's Avatar
What type of silicone for Tent ends?
Had this happen today - looks like a fairly easy fix - what type of silicone do I pick up?
Also, is it ok to run the silicone the length of the bunk end (looks like it should have come that way)?
Name:	ImageUploadedByForest River Forums1443380112.004462.jpg
Marine3038 is offline   Reply With Quote
Old 09-27-2015, 02:53 PM   #2
Attachment 90058
You want ProFlexRV Flexible Sealant Clear. This is an adhesive caulk and is what the factory uses.
______________________________
2013 Rockwood Roo 183L
2012 Toyota Tundra CrewMax
olwalker is offline   Reply With Quote
Old 09-27-2015, 04:47 PM   #3
Same thing happened earlier this spring. Got clear silicon sealant from Menards. Ran it the entire length, and also the length of the white plastic strip. Tapped down the white channel. Took a few pieces of masking tape across the front on the outside, to make sure the canvas would slide back out . Hope this helps, it is holding just fine.
2015 ROO ikss
syogerst is offline   Reply With Quote
