Old 07-02-2015, 09:54 PM   #1
What years have the water filter problem?
I see alot of posts but not sure what years have these problems or has it been fixed on later models. I have a Roo 21SS 2010 and it doesn't have the water filter installed although the previous owner has left a replacement one in the camper. I'm scared to death to even touch it.
thomsonr is offline   Reply With Quote
Old 07-02-2015, 10:12 PM   #2
WFD
It's an ongoing problem...use an outside filter instead. Ours is a 2014...first thing I did is pull it out, before ever running water through it.
2016 Chevy Silverado 2500 Duramax
2016 Rockwood 8289WS, Diamond Pkg.
WFD is offline   Reply With Quote
Old 07-02-2015, 10:23 PM   #3
Considering the Roo is such a great hybrid trailer otherwise what a shame.
Old 07-03-2015, 12:31 AM   #4
Roocrew1's Avatar
2012.... And I haven't had an issue. However, I keep a look out for it to happen. This year, I used a camco outside, and purchased a Home Depot filter (2 for $8) to replace the expensive one inside....and had great tasting water this last trip. Again, no filter issues on our 2012 yet.
Roocrew1 MI
2012 233S
2010 Expedition EL Limited 3:73 with Air Suspension
Roocrew1 is offline   Reply With Quote
Old 07-03-2015, 02:36 AM   #5
Never had a filter issue with my 2008 Shamrock 183. In fact, the filter would refuse to loosen at all - even with the wrench - unless I opened the kitchen faucet. It sealed that tightly.
The filter housing looks different on my new camper and I guess I have one of the filters that tends to unscrew. There is an arrow on the filter holder that is supposed to be lined up with the housing which I did and thus far I've noted no movement. It's not like the unit is on a spring, ready to fly apart. I put a piece of tape from the holder to the housing just in case.
2015 Shamrock 231KSS, Oyster shell
2016 Chev Silverado LT Z71 Ext. Cab, 4x4, 5.3L V/8
Reese Straight Line WDH, 2000W Honda Gen.
2 Old Town kayaks & 2 Boston Terriers - Zoey/Gonzo
Lar & Ruth
55 nights camping 2015, 45 in 2016, 42 in 2017
CNYCamper is offline   Reply With Quote
Old 07-03-2015, 03:38 AM   #6
Just a member
kandl's Avatar
What are the details on the label on the filter bowl? If it's a Water Pur CCI-10 filter assy, you should be fine. We've had no issues with ours in four yrs and hundreds of days pressurized.
Keith, Lori & the Wild Bunch
TT: 2011 Rockwood 8293RKSS
TV: 2009 Dodge Ram 1500 CC 4x4 (ya.. it's got a Hemi
kandl is offline   Reply With Quote
Old 07-03-2015, 04:52 AM   #7
My experience last weekend would lead me to recommend everyone to remove the cannister completely. It didn't unscrew...the housing had a hairline split which let water spray all over the pump compartment and leak into the bathroom. It's an early 2015 23ikss
Jim and Deb
Many times..asst grandkids
2015 Shamrock 23ikss
2013 Ram 1500
jking46 is offline   Reply With Quote
Old 07-03-2015, 12:24 PM   #8
Rsharrer's Avatar
We picked up our 2014 Rockwood 8289WS in Indiana in July 2013. In route home to California, the water filter detached (unscrewed) from the housing. No matter how tight it was screwed on, nor whether using the 12 volt water pump or shore water, it would simply come off. Stopped at a dealer in South Dakota and he said he had not seen this happen before. Getting it replaced under warranty was problematic (process too time consuming and we were on the road) and so I just paid him to remove and bypass it. Have used an external filter attached to our hose since with no problems. The original filter was also installed in a place making filter replacement difficult.
Rsharrer is offline   Reply With Quote
Old 07-03-2015, 12:54 PM   #9
B and B's Avatar
Agreed a bad spot to change. No issues here but according to the distributor at Goshen last summer the filter has to be installed in the filter head firmly and then the canister made wrench tight. Anything less than this it will loosen.
2017 Heartland Bighorn 3575 Elite with Reese Sidewinder
2016 Ford F 350 SD PS 6.7 SRW Crew Pucks and Reese 18 K Elite
2013 Rockwood 8289WS 2012 Rockwood 2703 SS TT 2007 Golden Falcon 38FLA PM 1983 Corsair 21RB
2015 Ford F250 PS '13 F150 3.5 Eco '09 F150 5.4 l 1987 Merc Grand Marq 1982 Ford E250 CW
Old 07-03-2015, 01:03 PM   #10
I've pulled my Rockwood Minilite 2104 over 12K miles in the 3 years I've had it. Two years ago we did a 7 week, 14 state, 8000+ mile trip. Never had a problem with the filter .... ever.
When doing the pre-delivery walk-around, the advisor (who happened to be the dealership owner) insisted that I get a water pressure regulator. He even gave me 50% off ... and it wasn't that much to begin with. He claimed uncontrolled water pressure could cause all sorts of problems and that you can't trust the water systems at parks. I've used it every time I've hooked up. Could non-use of a regulator be a contributing factor with this problem?
2012 Rockwood MiniLite 2104
gastan is offline   Reply With Quote
water, water filter
