Old 04-02-2013, 09:09 PM   #11
asquared's Avatar
stupid question do you put the pizza stone on the rack under the dish or on the bottom of the oven?
asquared is offline   Reply With Quote
Old 04-02-2013, 09:21 PM   #12
Mountainmanbob's Avatar
some foil under rack
Originally Posted by buschmann View Post
the trick to using the oven. Any help would be great! Thanks!
no stone
we just put some foil under rack
so as to disperse heat better
we use a stone at home
but
not in the RV oven
seems to work fine for us
Mountainman
Mountainmanbob is offline   Reply With Quote
Old 04-02-2013, 09:37 PM   #13
Just Love to Camp
TheFordes's Avatar
Talking
I asked the same question. See post#10 for answer
Camped 54 Night 2012
XLR Thunderbolt 386*12
"Bertha The LeadSled" is her name
2012 F450
Virginia
TheFordes is offline   Reply With Quote
Old 04-02-2013, 09:43 PM   #14
I have an $.88 glazed tile from lowe's resting on the very bottom of the oven it's lasted through six firings of the oven now. My oven was malfunctioning and used to climb hotter and hotter no matter where it was set. Once hit 550 before I shut it off. The dealer replaced the thermostat so now it stays where it is set. The little heat sink seems to even out the oven temp. I know there are ceramic and porcelain tiles, maybe it makes a difference which it is whether it breaks or not. I don't know which mine is but so far so good.
comfun1 is offline   Reply With Quote
Old 04-02-2013, 10:14 PM   #15
We have set our stoneware on the metal shelf directly above the burner. Works great at evening out the temperature in the oven. I believe I found that solution here in these forums as well.
2004 F150 4.6 Griffin tuned
2010 Wildwood 24FBS
johnleann is offline   Reply With Quote
Old 04-07-2013, 07:30 PM   #16
TomStacey616's Avatar
Ditto
2010 Tundra DC SR5 TRD 5.7L towpkg (gone)
2008 F350 Lariat CC DRW 6.4PSD
2013 PT Tracer 3200BHT
BlueOX SwayPro (used when hauling cart too)
TomStacey616 is offline   Reply With Quote
