Old 04-15-2016, 01:13 PM   #11
DaGrinch's Avatar
Originally Posted by OldCoot View Post
I have only used the X Chocks for 10 yrs now and never had a trailer move with the 4 tires locked with them. See no need for extra wheel chocks. I install them before I unhitch and that's the last thing I remove before towing.
x4!
"Sunny" the 2017 Sunseeker 3010DS
2006 Jeep Liberty Toad
.... and lovin' life........MOST of the time.
DaGrinch is offline   Reply With Quote
Old 04-15-2016, 01:13 PM   #12
KMP44's Avatar
So do I, but the little instruction sheet that came with them said to use the traditional chocks first and not to raise/lower the tongue or landing gear with the X-Chocks in place. Not sure if there is a good reason for this or if its just a "lawyer sticker."
2017 F-250
2013 Rockwood Roo 23 IKSS
KMP44 is offline   Reply With Quote
Old 04-15-2016, 01:25 PM   #13
Brother Les's Avatar
My wife said to use the wheel chocks... so I use them.
Brother Les
Old 04-15-2016, 01:26 PM   #14
Dave Lyon's Avatar
you did the right thing Les
Dave, Southern,ON
2017 GMC SLT HD All Terrain Crew Cab (6' 6" Box) 2012 Roo 23SS
E2 Trunnion WDH (1,000 lb / 10,000 lb)
Dave Lyon is offline   Reply With Quote
Old 04-15-2016, 01:48 PM   #15
(Dry Huunday)
DreiHunde's Avatar
I use X-chocks with Andersen levelers and conventional chocks on the other side. If no leveler needed then chocks both sides.
Beau & Sue
FurKid Express
2015 Coachmen Catalina 303RLS
DreiHunde is offline   Reply With Quote
Old 04-15-2016, 02:06 PM   #16
Left Coast
X5
Old 04-15-2016, 02:11 PM   #17
Pickin' & Campin'
X6
Days Camped: '15=22 '16=46 '17=30 '18=4
Old 04-15-2016, 02:21 PM   #18
Professional Curmudgeon
The wheels on my old TT were closer together than my new one, so I used x chocks on it. One time I forgot to remove them prior to pulling forward. They popped out quite easily.
I've had the TT move unexpectedly, and the feeling that you get inside knowing that all you can do it hope it stops soon is one I'd rather not endure again any time soon. I use big ol' honkin' black rubber chocks from Harbor Freight front and rear on mine. In fact, I set one, pull up on it a bit, then set the other so they are nice and tight. Anything after that is simply to cut down on shake in my book.
2002 Forest River Flagstaff 8528RLS
2014 Coachmen Catalina 253RKS
2016 Keystone Summerland Mini 1750RD
2012 F250 Lariat 6.2L Crew Cab FX4
wrvond is offline   Reply With Quote
Old 04-15-2016, 02:39 PM   #19
I tighten them tight enough that I use them for the hitch pull test. I have never in 10 yrs ever been able to move the trailers. I would think in your particular case they were not tightened or someone loosened them unbeknown to you.
Old 04-15-2016, 03:19 PM   #20
cheeseheadjim's Avatar
THANKS for all the helpful comments. I will probably go ahead and use wheel chocks as well as X-chocks. Kind of a "belts & suspenders" solutions for sure, but I don't mind having both of them. Being a newbie to the 23IKSS (vs my pop-up), I would rather be safe than sorry.
Jim S.
cheeseheadjim is offline   Reply With Quote
chocks, wheel
