Old 04-17-2016, 07:31 PM   #31
Originally Posted by CWSWine View Post
When I was picking up my new 5er the tech saw a set of XChocks and told me that the new Lippert suspension the Xchocks will cause the tire alignment problems. He said majority alignment problems he has seen people were using XChocks.
What is the new Lippert suspension? Pictures please.
Old 04-17-2016, 07:43 PM   #32
CWSWine's Avatar
MOR/Ryde CRE 4000 Suspension System.
2017 Fleetwood Discovery LXE 40D Diesel Pusher 41 foot. CC 5740
2017 Solitude 310GK-R Pick Up Oct 24th.
2016 GMC Denali 1 ton Cargo Capacity 3722 lbs
Sold 2016 Keystone Montana 3711FL
Sold - 2015 Crusader 315RST 5th Wheel -
2015 Ford F350 SRW Cargo Capacity 3744
CWSWine is offline   Reply With Quote
Old 04-17-2016, 07:47 PM   #33
Justice12t's Avatar
If it cannot handle xchocks than I would hate to see it have a few hundred miles on some of these US roads...
Unless people are extremely over tightening them...
2016 Prime Time Crusader 294RLT
2016 Days Camped - 31
2017 Camping Blues - ...
Justice12t is offline   Reply With Quote
Old 04-19-2016, 12:25 PM   #34
Originally Posted by BC Boy View Post
Please let me know what you find regarding the Fastway One Step. I am interested in either the X-Chocks or the One Step and would appreciate some real world feedback from someone who has used both, thanks!
I used the X-Chocks on my Rockwood, which I sold, and the One Step on my Heartland, so it is hard to do a direct comparison. The X-Chocks lock the tires but are harder to install and you are supposed to chock first. I can't see any fore and aft movement with the One Step when people walk around in the trailer, so in that regard it seems to do the job. I don't you can expect any chocks to do any more than that to stabilize. I'm thinking of adding some scissor jacks just in front of the wheels to eliminate some of the bounce caused by chassis, spring and tire flexing.
2015 GMC Sierra 1500
2013 Heartland North Trail 28BRS
spudston is offline   Reply With Quote
Old 04-19-2016, 01:07 PM   #35
I chock, then disconnect, then install the X-chocks.
No matter what you may do relative to the tires and wheels, you are still at the mercy of the suspension, which you can't "lock." The only thing you can do to deal with that is using stabilizers or jacks directly on the frame. That typically involves a larger expense and additional work to set up and take down.
So do whichever works best for you.
2011 Traverse LT, 3.6L, FWD
Old 04-19-2016, 07:40 PM   #36
wicked1's Avatar
Do X-Chocks really help? I am thinking of getting a pair as I have heard one set isn't enough?
2016 F350 Supercew Short Box 6.7 PowerStroke Diesel
2013 Crusader 295RST Touring Edition
wicked1 is offline   Reply With Quote
Old 04-19-2016, 07:57 PM   #37
Get 2 and use one on each side.
Old 04-19-2016, 08:07 PM   #38
flymhi's Avatar
X2. x-chocks do make a very noticeable difference on the movement (rocking and sway) after they are tightened. I used 2 on my 21SS for 3 years and never had any issues. My new unit has the spread axle design so I'm interested to see if the xtended x-chock make it just as stable as the old style. If you do decide to buy them, check around as the prices vary widely. The dealer gave me pricing of $85 each for the xtended but I found them for $55 online through a google search. same goes for the regular x-chocks.
2015 Denali Duramax 2500
2017 Coachmen 229TBS
2010 Shamrock 21SS - sold!
flymhi is offline   Reply With Quote
Old 04-19-2016, 08:10 PM   #39
I think rather than spend $110, I would try to come up with a way to modify the regular ones to fit the spread axles, but that's just me being cheap!
Old 04-19-2016, 08:30 PM   #40
flymhi's Avatar
The thought occurred to me but sold the old ones for $65 so the new ones didn't hurt my wallet so much.
chocks, wheel
