06-14-2011, 08:28 PM
Which hitch?
I am going to be towing my new rock wood roo 19 with a 2004 mountaineer, 4.6 liter V8. I am new to all of this. My dealer is recommending the Husky (valley) sway bar/weight distribution package. Is that what I need? Do I need something better? Thanks.
06-14-2011, 08:32 PM
you are going to get alot of diffrent responses to your question due to each one of us uses a diffrent setup
I use the Equalizer 4 point setup. it is an all in one sway control and weight distribution - I like it the only exception I have had to do was upgrade my hitch on the truck cause my factory hitch flexes so upgraded to a class V hitch (which is overkill but it puts me in a better spot to upgrade trailers later on)
if I had to make a choice it would be either the Equalizer or the Reese Dual Cam
2011 Rockwood Mini Lite 2306 - Matt
2004 Dodge Ram 1500 Qaud Cab 4x4 with 35" tires and 3.92 gears, Dynatech Longtube Headers & Fabtech 6" lift + Superchips with shift Tuning
Nights Camped 2011 (37) - 2012 (16)-2013 (2) -2014 (5) -2015(0)
USMC 91 - 95 - F/A-18 Aviation Ordnance
06-14-2011, 09:14 PM
I have a Husky Centerline and like it.
Kristina
2016 Rockwood Premier 2317G
2021 F150 XLT
Previously:
2005 Fleetwood Seapine, 2012 Rockwood Roo
2015 Sunseeker, 2017 Fleetwood Pace Arrow
06-15-2011, 10:22 AM
I think the best hitch for you is whichever one you are going to learn to use well.
This is very important in that too many campers IMO do not learn their system enough to judge when an adjustment is needed or how to adjust in situations when tongue weight or TV loading are changed.
It is tough to know what is best for your setup if you have no experience with WD hitches. But, if you really trust your dealer and believe they will do a competent job, then I would recommend going with their recommendation. You will still need to learn everything there is to know about the hitch, however.
Just judging from the number of posts being made on FRF and elsewhere (and from my observations at campgrounds near me) the Equal-i-zer and Reese Dual Cam seem to be the most popular for trailers our size. They are popular because they have been around a long long time, are proven technology, and offer convenience in that sway control is built into the hitch.
Husky and Blue Ox have favorable reviews as well but are not seen as often in my area. This doesn't mean they are not as good as the Equalizer and Reese.
Scott
DW, 3 Kids and our Goldens
2012 Shamrock 233S
2008 Toyota Sequoia 5.7L 4WD
06-15-2011, 10:30 AM
how much are they asking for the Husky? does it have built-in sway control like the Equalizer or Reese Dual-Cam?
you can get the Equal-i-zer for around $439 with free shipping. i have one and i love it. it has 4-point sway control and no chains or cheap friction anti-sway bar.
the Equalizer and the Reese D/C are the most recommended WDHs on all RV forums.
06-15-2011, 10:36 AM
I have the Reese Dual cam and like it so far. avoid the "sway-bar" type systems. They are passive sway control (corrects the sway after it already starts to sway) and you have to remove the sway-bar before you can make any really tight turning or back up.
The reese dual cam system stops the sway before it even happens and you don't have to remove anything to back up.
Had the draw-tite sway bar on my old pop-up and hated it.
I only have about 300 miles of experience with the dual cam setup- but I like it so far.
2012 Keystone Passport Express Super Lite 235EXP (Equal-i-zer)
2012 Forest River Rockwood Roo 21SS(Reese Dual cam) (broken)
2009 Chevy Silverado 1500 4x4 5.3L 3.73(G80) Z82 Z85
Whelen warning setup, VHF/UHF radio, CIPA slip on mirrors & brakeman compact
06-15-2011, 11:08 AM
Kristina
2021 F150 XLT
Previously:
06-15-2011, 01:30 PM
Thanks so far for all the posts. I still am not sure whether to go with the husky that the dealer has, or order one of the others and have them put it in. The equalizer gets great reviews. The husky link looks impressive.
06-15-2011, 05:35 PM
you still didn't say how much the dealer is charging for the Husky.
a WDH with a friction anti-sway bar is inferior to those with integrated sway control.
06-15-2011, 08:39 PM
I think it has integrated control? He said 269 installed, which worries me a great deal. That seems way too cheap.
06-15-2011, 10:36 PM
I think i paid a little too much- but my reese dual cam setup was around $900 installed by the dealer. it was going to be about $500 with the dual friction sway control.
06-17-2011, 08:41 PM
Okay. So I clarified. It is the "husky combo", which is their standard weight distribution hitch and sway bar. He says he's never had a complaint, and he doesn't want me to spend more than I have to. Mind you, he threw it in with the deal. It is what they install most. It is NOT the husky center line. They have equal-I-zer hitches in stock, but he thinks it is too much hitch for the trailer, and he will have to charge me more. The trailer GVWR is 4660, dry hitch weight 262, 21 feet (rock wood roo 19). The TV is a 2004 mercury mountaineer, 4.6L V8, RWD, rear axle ratio 3.73
06-17-2011, 11:36 PM
Equalizer's E2 series is way better than that Husky and isn't much more.
look for the 600/6000lbs. setup from RVW. either $261 or $323, depending on which of the two you get.
Check RVW's prices and take them to your dealer.
the Equalizer is NOT too much hitch for your TV. lots of Roo/Shamrock 19 owners are using it.
06-18-2011, 07:07 PM
Thanks everyone! Gonna insist on the equalizer, but prob pay more. Hopefully he won't try to push me around too much.
06-18-2011, 07:18 PM
if you need a copy of what someone else paid for the Equlaizer I can email you a copy of my invoice so you know are getting a good deal
06-18-2011, 07:34 PM
use RVW's prices. remind them RVW ships the Equalizer for free.
06-22-2011, 07:55 PM
Thanks everyone, insisted on equalizer hitch, but had to add some $$$ to the bottom line. Worth it to be safe.
06-22-2011, 09:25 PM
I just tow the TT for DW!
Good choice on the Equalizer. Hope the dealer didn't overcharge you too much for it. Our dealer wanted over $700 for the 12k/1200 we needed, but I was able to get it online with free shipping for less than $440, which inlcuded the hitch, shank, and ball.
2008 Ford F350 King Ranch Lariat SD CC 4x4 V10 4:10
2012 Rockwood Windjammer 3008 - Equalizer 12k
2007 EZGO TXT Lifted/Custom Golf Cart
Nights Camped: 2011(52) 2012(65) 2013(65) 2014 (51) 2015 (40)
