Old 05-12-2013, 10:35 AM   #51
CDNWhiskey's Avatar
2013 - 23SS .... No L brackets
CDNWhiskey is offline   Reply With Quote
Old 05-13-2013, 01:31 AM   #52
Grizzlygibbs's Avatar
Forgot a picture, but my table in my 2014 233s definitely has L-brackets on the bottom. Got side tracked and forgot the picture and to check the top portion for side brackets.
2008 Toyota Tundra Crewmax Limited w/tow mirrors, 5.7L, 4.30 gears, six speed tranny, towing package, Firestone Ride Rite airbags.
2014 Rockwood Roo 233s, PI HW30-C, Equalizer 10k 4 way hitch,
Grizzlygibbs is offline   Reply With Quote
Old 05-14-2013, 06:30 AM   #53
2014 21ss I don't think I have the L brackets. I will have to check. I have the death wobble though...
redrider13 is offline   Reply With Quote
Old 05-15-2013, 10:05 AM   #54
I have this table in my brand new 2011 23RS (sat on the lot for a couple years). This one had nice welds in the places people are putting L brackets so adding L brakcets won't help. It's got more wobble than is good, but I think due to these it's "livable".
After analyzing it a few times it seems that the wobble (on my unit with the welds) is coming from the 2 joints of the folding mechanism. I've wondered if simply stuffing a playing card in each of the joints would reduce the wobble. This is not a high tech solution, but it might work. If that works, One could just put a couple layers of black electrical tape over half of the joint to "tighten" up things a bit. The tape would likely have to be replaced annually or so, but it imght be a simple and invisible fix. I'll test it out and post some pictures if I think it's useful.
cobrageek is offline   Reply With Quote
Old 05-15-2013, 02:38 PM   #55
Here are some pictures I took this am if my L-brackets. Table in down position.
ID:	30580   Click image for larger version
ID:	30581   Click image for larger version
ID:	30582   Click image for larger version
ID:	30583   Click image for larger version
Old 05-28-2013, 09:36 AM   #56
Well, I used some electrical tape to try to tighten up the joints, but I found that if I got them too tight the latch wouldn't lock in place. I pulled some back off so I could get it latched and I think it helped a bit, but it's still not as stable as I would like.
At least for now I think we're going to handle it by not filling the cocoa mugs to the top :-). I don't really have any other "fix" ideas other than complete replacement.
Old 05-31-2013, 08:25 AM   #57
Hi, hate to jump in but I do have an unrelated question. Who is the "Roger" and how to I write him? I would LOVE to find a way to tell them about the new design of latches and how they simply will not last. Ours broke when the dealer was showing us how easy they work. Anyone with even a bit of engineering knowledge knows plastic and steel just won't last. It's not bad when two people can close them at the exact same time but one person puts too much pressure on one side. Maybe I should design a steel replacement and sell as a aftermarket...
theroo2 is offline   Reply With Quote
Old 05-31-2013, 08:54 AM   #58
ddemme's Avatar
Roger is:
Roger Beiler
Warranty Administrator
Rockwood: Utra Lite, Mini Lite, Roo
Flagstaff: Super Lite, Micro Lite, Shamrock
rbeiler@forestriverinc.com
Phone: 574-642-2640 x124
Fax: 574-970-6881
Drew & Kendra
Lucky & Bentley the camping dogs
2011 Ford F-150 SuperCrew EcoBoost w/tow pkg.
2012 Rockwood Roo 23SS
ddemme is offline   Reply With Quote
Old 06-12-2013, 06:44 PM   #59
Mad4sax's Avatar
My 2013 233s Roo developed a wobbly table after just a couple of trips.
I am getting the camper ready for this season and decided to modify the table.
I plan on either getting a friend to weld it or install L brackets.
When I disassembled it I found 2 totally different screws.
The shorter screws were the real wobbly side.
Wrong size and wrong threads.
Nice quality control!!!
2013 Shamrock 233S
Mad4sax is offline   Reply With Quote
Old 06-14-2013, 06:41 AM   #60
Hey everyone we had the same problem..Took it to a friend and we decided to build a weld at the base of the vertical tube and the floor tube. It appears to work. Unfortunately we stored the ROO and haven't had a chance to set it up. But this coming Tuesday July 18th we will have that chance. Coming out to get ready for our next trip. I will post if this idea did work
Manzie49 is offline   Reply With Quote
