Old 11-28-2015, 07:11 PM   #11
Eric F.'s Avatar
That is where we are going!!!
Eric F.
2015 Flagstaff Shamrock 233S
2012 Ford F250
Eric F. is offline   Reply With Quote
Old 11-28-2015, 09:03 PM   #12
mike.t's Avatar
Not in to the snow thing but fishing is great in the spring and early summer all over with in 30/40 miles.
2015 Salem 27RKSS
2015 Ram 2500 CC 4x4 Cummins
55' Chevy Bel-Air
Burgers on the BBQ and a cold beer
mike.t is online now   Reply With Quote
Old 11-28-2015, 11:42 PM   #13
I am camping right now, and have already winterized the camper. We are using the shower house in the Kentucky campground, and using an old Thetford Porto-potty from our pop-up days. That way I won't have to winterize again when we get home.
The heated mattresses work well, so I wouldn't worry about insulation under the mattresses. Reflexfix in the bunk Windows may be helpful, but use bunk end covers if you have purchased them. Expect condensation and take some old towels for drying if needed.
While I ordered the factory tank heaters, I don't plan to use except for occasional nights when it drops into the upper '20's.
2014 F150 SCrew 4x4 Max Tow Heavy Duty Payload 3.5 Ecoboost 6.5' bed Ingot Metallic Silver
2015 Rockwood Roo 21SS
Velosprout is offline   Reply With Quote
Old 11-30-2015, 09:29 PM   #14
I spent several winters out and about in single digits with my ROO 21SS. Sounds like you covered all the angles. I never heated my tanks and did unhook the hose at night. PUGs are great but also reflectix panels in the bunk end window panels and under the mattresses makes a big dif. I also found several items to be highly functional as needed. A highway flare in lieu of a MAP torch is very helpful to thaw the CG water supply pipe (really bad set of weather related circumstances) and a heat PAR lamp type bulb to thaw out the dump valves. It's all good once you get past the frostbite!
rvrobocop is offline   Reply With Quote
camping, winter
