Old 10-28-2015, 04:23 PM   #1
Winterization 101
I have been following this forum since I bought a 21 BD. Looking for advice.
This is my fourth camper. I am totally happy with all of the help from you all.
But am not happy with comments on winterizing your camper.
I am a civil engineer with a minor in hydrology. IMO you should not pump
contaminated air through your lines unless that is all you plan to do.
There is no need to do this if you are going to then pump RV antifreeze through
the lines. The antifreeze will push out all of the water in the lines. The antifreeze will displace all of the water out, and there will be no need to "top
off" the lines to keep them full. Once the line are empty of water that could
freeze , you are done. You can open all of faucets and low drain lines to
drain any antifreeze in the system.
Empty water lines have no liquid in them to freeze.
dogevans is offline   Reply With Quote
Old 10-28-2015, 04:29 PM   #2
Bilcin's Avatar
How do you remove the water from the city water inlet and hose? Just pour AF in the inlet?
Bill & Cindy McKenna
Philadelphia PA
2015 Palomino Puma 32DBKS
2005 Ford Excursion 6 liter Turbo Diesel
Bilcin is offline   Reply With Quote
Old 10-28-2015, 06:09 PM   #3
UmptySquat's Avatar
I've heard (haven't tried it yet) that with the pump on you depress a check valve in the city inlet until the AF comes out. Trying it this weekend.
2013 Toyota Tundra 5.7L
2015 Apex 288BHS
UmptySquat is offline   Reply With Quote
Old 10-28-2015, 06:25 PM   #4
2015 Apex 288BHS
Use a wood pencil with the eraser to push on the small round pin in the center of the port while the pump is on. It may take a really good push and prepare to get somewhat of a shower until you see pink.
Mr Havercamp is offline   Reply With Quote
Old 10-28-2015, 07:14 PM   #5
WFD
Stand off to the side when you do this or you will get showered with pink antifreeze...Don't ask me how I know this!
2016 Chevy Silverado 2500 Duramax
2016 Rockwood 8289WS, Diamond Pkg.
WFD is offline   Reply With Quote
Old 10-28-2015, 07:18 PM   #6
WFD
Interesting because many claim that by not blowing the water out beforehand the antifreeze will be diluted, but you say the water will get displaced.
Old 10-28-2015, 07:39 PM   #7
cogito ergo moo
Cowracer's Avatar
Don't know exactly what you mean by "contaminated air"...
Tim
FROG Member MO-0008-571 Since 20124444444444My Project Blog: https://cowracer.blogspot.com/
2016
Rockwood Signature Ultralite 8329ss
Rallies Attended:
Cowracer is offline   Reply With Quote
Old 10-28-2015, 09:37 PM   #8
Tim
I think he means contaminated from the air compressor and that you shouldn't run that through your water lines. But then again if you ever had the opportunity to see inside a municipal water main when they pull one out of the ground, and see whats inside it, I don't know why in the hell it would matter.
Old 10-28-2015, 09:39 PM   #9
Campster's Avatar
Tim
The air under the sheets, after attending a chili feed that evening.....
Campster is offline   Reply With Quote
Old 10-28-2015, 10:33 PM   #10
Just a member
kandl's Avatar
Precisely why we have always employed the blowout method to winterize. Some AF for the p-traps and the seal on the potty. And... nothing to flush out in the spring.
Keith, Lori & the Wild Bunch
TT: 2011 Rockwood 8293RKSS
TV: 2009 Dodge Ram 1500 CC 4x4 (ya.. it's got a Hemi
kandl is offline   Reply With Quote
winter
