Old 09-25-2016, 07:55 PM   #1
Winterizing 17 Roo 19 with an antifreeze inlet
Confused to say the least. Could someone explain the proper/best procedure to winterize a 17 Roo 19 with an antifreeze inlet. I will drain all fixtures, use the air compressor method to blow out the lines and drain again. Do I still have to do this? And my next question is what is the best procedure to get the AF in this system? Thanks in advance!
westernmaroo is offline   Reply With Quote
Old 09-25-2016, 10:13 PM   #2
Moderators' Assistant
bikendan's Avatar
There are tons of YouTube videos on winterizing.
Have you watched any?
Dan-Retired Firefighter/EMT
2016 PrimeTime TracerAIR 255, pushing an '07 Chevy Avalanche
Equalizer WDH and Prodigy BC
Old 09-25-2016, 10:19 PM   #3
rbq
Can't address the antifreeze as I have never used it except in the P-traps in the drains. Be sure & turn down the pressure on the air compressor to about 35-40 PSI so you don't blow the lines. Also don't forget to drain the water heater & by pass.
2001 Chevy Silverado
2011 Rockwood Roo 233S
rbq is offline   Reply With Quote
Old 09-25-2016, 11:02 PM   #4
When I had my Roo 19, I just blew out the water and only put the AF in the P-traps. And we see -20F here.
I did the same last winter on my Mini-Lite.
Just make sure you do a good job blowing out the water if you're not going to use the AF.
2011 Traverse LT, 3.6L, FWD
Old 09-26-2016, 03:45 AM   #5
Sorry Dan, but the 2017 Roos have an inlet outside the hybrid to connect the antifreeze......not many videos on that type of setup!
Drenjoey is offline   Reply With Quote
Old 09-26-2016, 09:29 AM   #6
This is what I was going to do but I was wondering if the antifreeze inlet would make the process faster, better, easier? If not I will blow out the lines, drain and pour a little AF down the traps. Thanks for the replies!
Drenjoey - couldn't find a "one" that uses the anitfreeze inlet. Have you?
Old 09-26-2016, 12:37 PM   #7
I have a 2016 Roo 183 (bought last spring) with the external AF inlet. Prior to winterizing, I researched it quite a bit and decided to just drain all the lines/tanks and use AF (no compressor). You'll find A LOT of opinions on this. Doing both just seemed like overkill to me,but i know a lot of people do it. Better to be safe than sorry though.
For the outside inlet, I cut the end off of an old garden hose and stick that end in the AF container. Attach the other to the inlet. You'll find a bypass valve next to your water pump that has to be turned so that the pump pulls from the AF inlet instead of the freshwater tank.
You'll need 2-3 gallons of RV antifreeze to do the whole thing, including pouring some in your traps.
Eric & Abby
2016 Rockwood Roo 183
2014 Ford Explorer Sport
ebcobra93 is offline   Reply With Quote
Old 09-26-2016, 01:11 PM   #8
Old Eeyore's Avatar
X2
Biggest risk is not watching the level in the AF jug and sucking air - I use the gallon jugs - as I can't see the hookup from inside my 23IKSS.
Oh - I assume you know this since this is not your 1st rodeo - don't forget to bypass and drain the water heater first.
2016 Roo 23IKSS / 2011 Tahoe
2011 Roo 21SS / 2011 Tahoe
2006 Bayside / 2006 4Runner
1999 SantaFe / 2001 Sienna
1967 Nimrod / 1998 Outback
Old Eeyore is offline   Reply With Quote
Old 09-26-2016, 01:14 PM   #9
Yes, I didn't mean my reply to be a step by step procedure. Definitely drain/bypass the water heater. ☺️
Eric & Abby
Old 09-26-2016, 01:37 PM   #10
Old Eeyore's Avatar
Sorry, the reminder was meant for westernmaroo.
roo, winter, antifreeze, winterize
