Old 10-06-2014, 08:55 PM   #11
ficksters's Avatar
already?
2014 Shamrock 23IKSS
2007 Chevy Tahoe 5.3L V8 with 3.73 rear end, Primus IQ Break Controller, and Equalizer Hitch
DW (Not allowed to say)
DD (3 year)
DS (6 months)
ficksters is offline   Reply With Quote
Old 10-11-2014, 09:04 AM   #12
I am a bit confused myself. I am a newbie to this and would like to save myself some money by winterizing myself. I also have the antifreeze intake connection on the outside of my TT just below the city water connection. I have a 2015 23IKSS. Does this mean I am already set up to winterize? The antifreeze intake connection has a female connection, so I assume this is intended to hook your hose up on the outside and stick the other end into the antifreeze jug? Do I still need to bypass anything near the pump? I also have the water filter system. It was a pain to install when I purchased the TT because I couldn't turn the housing. I tried turning it with the supplied wrench, but couldn't get a good angle because of where it is located. Do I need to bypass the water filter or just remove it? How do I know if I have any water in my FW tank? Does the city water connection actually fill up the FW tank? I have never used the FW tank as I always hook up to city water. There is another connection on the TT for FW, so I assume my tank is empty. At least that is what my panel says.
JWHybrid2B is offline   Reply With Quote
Old 10-11-2014, 09:48 AM   #13
Ford Idaho's Avatar
Yes your are set.
My unit came with a short tube of PEX with a 45 fitting.
The water heater.
Some people have removed the filter and then placed a clean plastic bottle filled with water in the cartridge to fill the dead space.
Under your unit you may find some tubes with caps or plugs remove them and let the water drain.
Old 10-11-2014, 09:48 AM   #14
KDHfan's Avatar
My local shop charges $60 to winterize. Considering the cost of our rigs, and how much we spend for gas, "toys," and campground fees, that's a small price to pay for peace-of-mind during the sub-zero winter nights. I will de-winterize myself in the spring... But not a lot of risk involved with that.
2015 Coachmen Apex 288BHS
2014 Toyota Tundra 5.7L CrewMax
2014 Toyota Tundra CrewMax 5.7L
KDHfan is offline   Reply With Quote
Old 10-11-2014, 07:54 PM   #15
wbdavey's Avatar
JWHybrid - I suggest that you pay a reputable RV shop to winterize your unit and to show you how it's done. You have too many questions and too much to lose.
2015 Rockwood Ultra Lite 2604 WS. Rear LR, large street side slide with small wardrobe slide in BR.
2014 Ram 1500 Eco Diesel Laramie Quad Cab.
wbdavey is offline   Reply With Quote
Old 10-11-2014, 08:14 PM   #16
jtownstumpjumper's Avatar
Location: Jonesboro AR--Home of Arkansas State University and the Red Wolves
Getting ready to pick up new 2014 fifth wheel Monday....when winterizing a unit with washer /dryer combo, does one need to do anything special with it?
Lloyd & Kathy & Kit(19 yr old cat)
2018 Forest River Palomino Columbus 383FB
2016 Chevy 3500HD SRW Z71 LTZ 4WD Crew Cab, DuraMax/Allison.
2014 - 38 nights/3500 mi.; 2015 - 66 nights/6260 mi.; 2016 - 44 nights/6106 mi.
2017-65 nights/6992 mi.; 2018-7 nights/1037 miles....9 nights booked
jtownstumpjumper is offline   Reply With Quote
Old 10-11-2014, 08:23 PM   #17
Regardless of how any valves are set, there should be a check valve preventing anything coming out of the fresh water input fitting. It should be located at the input fitting itself. At least that's how both motorhomes that I have owned were set up.
David, Sherry and our three fur kids, Nicholas, Finnegan and Bentley
2013 Coachmen Encounter 36BH
2014 Honda CR-V/ Blue Ox Autostop
DSurette is offline   Reply With Quote
Old 10-11-2014, 11:00 PM   #18
bikendan's Avatar
since this thread is in the Hybrid TT section and hybrids DON'T have anyplace for any washer or dryer, i suggest you post a similar question in the 5th wheel section or the Appliance section.
you'll get more responses in the appropriate section.
Dan-Retired Firefighter/EMT
Equalizer WDH and Prodigy BC
Old 10-12-2014, 10:31 AM   #19
I have re-posted....thank you.
winter, winterize
