Old 10-05-2014, 10:52 AM   #1
Winterizing
I have drained water heater, low point drains and tanks. Closed bypass to water heater and I think I found the valve to shut off the fresh water tank. When I hooked hose to antifreeze outlet and turned on pump it pumped the antifreeze out the city water outlet. Any ideas what I am doing wrong? The manual is not very clear.
Murf345 is offline   Reply With Quote
Old 10-05-2014, 12:36 PM   #2
Campster's Avatar
Antifreeze outlet? Not sure what you mean there...You need to suck the antifreeze into the input side of your 12v pump. On mine I just disconnect the water line on that side and connect a piece of hosing that I made. I put the other end of that hose in a gallon jug of antifreeze and suck/ pump it into the water lines. There should be a check valve on your city water inlet that blocks the water from leaking out of it when pumping out of your water holding tank. Look in the city water inlet and remove the screened washer, there should be a small button sticking out. maybe your check valve is stuck or malfunctioning. push that button, it should be spring loaded. Don't stand in front of it when you test it, if it is working water should squirt out of it while pushed and stop when you let go.
Campster is offline   Reply With Quote
Old 10-05-2014, 12:48 PM   #3
Name:	ImageUploadedByForest River Forums1412531799.275271.jpg
Old 10-05-2014, 12:49 PM   #4
This is on the outside of camper
Old 10-05-2014, 04:00 PM   #5
Campster's Avatar
That city water connection should have the check valve in it behind the washer....it stops the water from coming out of it while using the water holding tank and pump when there is no city water to connect to.
Old 10-05-2014, 04:11 PM   #6
BillyBass's Avatar
What type of trailer you have and do you have a water filter on it. On mind I switch the three value by the water tank then then switch values by the filter
2012 21' FR Micro Lite FBRS
2005 GMC Sierra 1500
2012 24 nites 2016 16 nites
2013 25 nites 2017 19 nites
2014 14 nites
2015 16 nites
BillyBass is offline   Reply With Quote
Old 10-05-2014, 05:40 PM   #7
wbdavey's Avatar
Originally Posted by Murf345 View Post
Attachment 64159
Murf - you need to read the fine print on that red sticker. You have to change the position of the suction valve on the water pump to draw from the winterizing hose instead of from the tank. Just run your hand along the winterizing hose and you'll find a small black valve just above the water pump.
2015 Rockwood Ultra Lite 2604 WS. Rear LR, large street side slide with small wardrobe slide in BR.
2014 Ram 1500 Eco Diesel Laramie Quad Cab.
wbdavey is offline   Reply With Quote
Old 10-06-2014, 06:48 AM   #8
Dave Lyon's Avatar
This would be my suggestion as well.
Dave, Southern,ON
2017 GMC SLT HD All Terrain Crew Cab (6' 6" Box) 2012 Roo 23SS
E2 Trunnion WDH (1,000 lb / 10,000 lb)
Dave Lyon is offline   Reply With Quote
Old 10-06-2014, 12:01 PM   #9
I found the valve and turned it. That is when the above happened. Tried it the other also. Is there another valve that I am missing?
Old 10-06-2014, 06:47 PM   #10
wbdavey's Avatar
Murf - there should be a check valve in the city water line before it joins into the discharge of the water pump. If you can find it, try to "mechanically agitate" it with something like a screwdriver handle. Hope this helps.
winter, winterize
