Old 10-22-2015, 05:19 PM   #21
rbq
Another vote for blow out water lines & pink AF in the traps & drains & toilet. Found an adapter at CW that fits the water hook up. Just be sure & turn the pressure on the air compressor down to about 30 PSI. Open all the valves one at a time. Don't forget to drain the water heater & turn bypass valves before blowing out lines.
2001 Chevy Silverado
2011 Rockwood Roo 233S
rbq is offline   Reply With Quote
Old 10-24-2015, 02:08 PM   #22
urocav2001's Avatar
Quick question, do I leave the low point drains open during air line blow out?
urocav2001 is offline   Reply With Quote
Old 10-25-2015, 07:50 AM   #23
CAT-RN's Avatar
Drain low point-- close it--blow out everything. Then open low point and blow it out. Then I leave low point open
Russell
CAT-RN is online now   Reply With Quote
Old 10-25-2015, 02:32 PM   #24
fedrocker's Avatar
Doesn't the antifreeze leak out (the antifreeze you poured in for the traps) if you leave the low point open at the end of your process ?
2011 Rockwood Roo 233s
2007 Tundra Crewmax, 5.7
fedrocker is offline   Reply With Quote
Old 10-25-2015, 02:43 PM   #25
urocav2001's Avatar
Not sure lol, I just put them back in and refilled everything with antifreeze
Old 10-25-2015, 03:06 PM   #26
dretired's Avatar
Blowing all lines out with air is a great idea. I like pumping the "pink Stuff" thru every line also. including the city water connection and the black tank flush line. I like the idea that my pump had anti-freeze in it... instead of water...and...also don't forget washer hot/cold lines
2014 Crusader 325 TE....2012.. F 250.. Supercab XLT, 4x2 , diesel....days camped 2011 ... 28.... days camped 2012...115 ... days camped 2013...155...2014...171 and counting
dretired is offline   Reply With Quote
Old 10-25-2015, 03:27 PM   #27
urocav2001's Avatar
What's the best way to pump antifreeze thro city connection?
Old 10-25-2015, 03:37 PM   #28
Ford Idaho's Avatar
The lazy guy in me would buy one of these and pump away.
Drill Pump - All Purpose Drill Water Pump
Old 10-25-2015, 03:56 PM   #29
Roocrew1's Avatar
I blow out the lines then pull the pink stuff into the water pump lines... then pour into the traps ...and some into the tanks.
Roocrew1 FL
2012 233S
2010 Expedition EL Limited 3:73 with Air Suspension
Roocrew1 is offline   Reply With Quote
Old 10-25-2015, 04:33 PM   #30
There are several schools of thought going on in here all at one time. There are a few hard rules that need to be taken into account. One, no anti-freeze in the fresh tank. Two, your wasting pink stuff putting it in your blk and grey tanks (assumed empty). Three, if you just blow things out, make sure your toilet flush valve has been blown clear of residual water because any settling there can cause valve freezing failure. To the guy who wants to force pink stuff into the city connection, better buy a lot of antifreeze, your going to need it, unless of course you can isolate your fresh water tank.
winter, winterize
