Old 10-27-2015, 01:40 PM   #41
When I left my low point drains open and started pumping and I freeze through all the anti-freeze ended up on the ground
Dinostop is offline   Reply With Quote
Old 10-27-2015, 03:20 PM   #42
TURBS's Avatar
Sounds about right.
Old 10-27-2015, 04:31 PM   #43
fedrocker's Avatar
That's what I thought would happen
2011 Rockwood Roo 233s
2007 Tundra Crewmax, 5.7
fedrocker is offline   Reply With Quote
Old 10-27-2015, 05:01 PM   #44
dretired's Avatar
Originally Posted by urocav2001 View Post
So its not a big deal not to put antifreeze into the city water connection? I mean that line should already be blown out from the air anyways before putting anti freeze in thru the antifreeze inlet.
If you don't "Blow the Lines out "... first... and pump pink stuff in... to push out the plain water..instead
2014 Crusader 325 TE....2012.. F 250.. Supercab XLT, 4x2 , diesel....days camped 2011 ... 28.... days camped 2012...115 ... days camped 2013...155...2014...171 and counting
dretired is offline   Reply With Quote
winter, winterize
