Originally Posted by GroovyTimes
So yesterday I went to winterize our Shamrock 21s and I can't get the drain nut off the water heater.
There is no way to get a wrench in the space with all of the mechanicals in the way and I don't have a socket large enough to fit over the nut. Is there a special tool needed? Any advise will be appreciated.
Also I was unable to locate the low point drains for the hot and cold lines. The owners manual we got is to generic and I didn't see information on locating them. I found the fresh water tank drain inside the cabinet next to the front bunk. Where should I look for the line drains?
Thanks,
Dean
You need a 1 1/16" socket can be 6 or 12 point. A 1/2" ratchet with 3-6" extension to clear your knukles. Plenty of pressue the first time, afterwards put back with light amount of teflon tape it will be much easier.
The drains should be close to your water heater access cover or your pump if you know where that is. Sometimes there will be valves inside on piping leading through the floor, otherwise there will be caps or plugs outside.
