Old 10-20-2013, 07:05 AM   #1
Question Winterizzzzzzzzzzing
This will be the first time I winterize a camper myself!
Shamrock 183 2013,has an inlet just for that specific reason....
I was told to connect straight to inlet and turn pump on....
Has anyone ever done this?
And how much RV antifreeze will I need?
Marco is offline   Reply With Quote
Old 10-20-2013, 07:10 AM   #2
Herk7769's Avatar
If you follow that advice, a lot (it will fill your 6 gallon water heater).
Check the FAQ forum for a great checklist that will get it done with less than a gallon.
HAM CALLSIGN - KC3FFW
Old 10-20-2013, 08:07 AM   #3
BillyBass's Avatar
Mind has two values by the water pump you have to which them first one open the value from the outside then the other will shut off the fw tank. then if you have 3 values by your hw then flip the top and bottom and turn off your bypass. Then you need a hose to hook up from antifreeze inlet on the os of trailer stick it in the bottle then turn on your water pump.You may need 2 gallons to do it
2012 21' FR Micro Lite FBRS
2005 GMC Sierra 1500
2012 24 nites 2016 16 nites
2013 25 nites 2017 19 nites
2014 14 nites
2015 16 nites
BillyBass is offline   Reply With Quote
expandable, hybrid, shamrock, winter
