Old 06-05-2014, 07:55 PM   #1
Old Fella
Aussiecat's Avatar
Wiring Electric Tongue Jack
I'm thinking about using a flat trailer plug to wire my electric tongue jack rather than hard wire to the TT, is there any reason why this wouldn't be a good idea? I would be using the spare flat receptacle on the TV.
Aussiecat is offline   Reply With Quote
Old 06-05-2014, 09:47 PM   #2
cogito ergo moo
Cowracer's Avatar
flat plug on the TV only has power when running light or brake lights are on. I doubt either of those has enough capacity (fuse wise) to run an electric jack.
Tim
FROG Member MO-0008-571 Since 20124444444444My Project Blog: https://cowracer.blogspot.com/
2016
Rockwood Signature Ultralite 8329ss
Rallies Attended:
Cowracer is offline   Reply With Quote
Old 06-06-2014, 08:57 AM   #3
Grizzlygibbs's Avatar
Why no just wire a switch to it? I am assuming you are trying to get away from a parasitic draw?
2008 Toyota Tundra Crewmax Limited w/tow mirrors, 5.7L, 4.30 gears, six speed tranny, towing package, Firestone Ride Rite airbags.
2014 Rockwood Roo 233s, PI HW30-C, Equalizer 10k 4 way hitch,
Grizzlygibbs is offline   Reply With Quote
Old 06-06-2014, 02:32 PM   #4
fonzie's Avatar
It should be wired directly to battery on trailer as it probably draws between 15 to 25 amps. If using the flat 4 wires plug off your truck, you will burn the fuse in the vehicle.
Fonzie
Old 06-06-2014, 02:56 PM   #5
Old Fella
Aussiecat's Avatar
Thank you. I saw where one of the manufacturers wires to a plug however it's probably the main plug they're using. It seemed like a clean simple way and something I could do ahead of time.
electric, wiring
