Old 03-22-2016, 02:22 PM   #11
JustB_Rad's Avatar
I'm a little longer than you, but I've got 2 4x6's stacked under each scissor jack and X-chocks and the camper still shakes when the 15 lb wiener dog waddles through the camper, so I'm adding another set of stabilizers mid ship in front of the wheels. Hopefully that does the trick because I'm running out of crap to add!
2016 Grey Wolf 26DBH following a 2014 RAM 1500 Outdoorsman
Life is good...Live it!
Nights Camped - (2014) - 16 in 6 trips (2015) - 20 in 6 trips
(2016) - 21 in 7 trips
(2017) - 12 in 3 and going seasonal for at least the rest of the year!
JustB_Rad is offline   Reply With Quote
Old 03-22-2016, 03:12 PM   #12
My roo 23SS has steady fast so far very good
Bluemax542 is offline   Reply With Quote
Old 03-22-2016, 04:21 PM   #13
wicked1's Avatar
Let me know how that works out I was thinking of doing the same thing just have to find a place to mount them, and not sure they will help because they do not stabilize the Roo that well to begin with
2016 F350 Supercew Short Box 6.7 PowerStroke Diesel
2013 Crusader 295RST Touring Edition
wicked1 is offline   Reply With Quote
Old 03-22-2016, 08:09 PM   #14
How about those stackable stabilizer jacks that come in a four pack? Anyone tried these? Maybe two in front and two behind the axles?Click image for larger version
Name:	ImageUploadedByForest River Forums1458695346.944257.jpg
2015 Shamrock 23IKSS
2004 Chevy Silverado 2500HD 4X4 Duramax
Manion is offline   Reply With Quote
Old 03-23-2016, 12:58 AM   #15
dado39's Avatar
Yes I have them don't help much my outrigger style seemed to help the most but still use them.
2014 roo 233S. 2008 saab 97x
dado39 is offline   Reply With Quote
Old 03-23-2016, 03:58 AM   #16
Mainframe's Avatar
One of the first things I noticed about my 2016 Shamrock 23WS was how solid it felt even just hooked up to the TV, I assume this is due to the suspension and stiffness of the frame etc.
I had a 2011 Kodiak single axle before this and hooked just to the TV it was literally a "bounce house" LOL and it shook and bounced a lot even when set up, I thought that is just the way a hybrid is and accepted it, but the WS seems to be very solid in that regard.
2016 Shamrock 23WS
Mainframe is offline   Reply With Quote
Old 03-23-2016, 04:25 AM   #17
Witch Doctor's Avatar
Originally Posted by wicked1 View Post
Interesting and cheap way, might need to try those because X-Chocks do not make a big different, I thought of putting a set of Electric Stabilizers found in 5ers but at $3000 way not worth it
I'm not sure we talking about the same thing but If I remember right they cost around 400.00 from LCI. I know OC cut some down on his trailer and installed them before the wheels and trailer is hard rock solid. Leave it to the OLD MAN to come up with something new, his mind never quits.... If your going to Goshin, they change out quite a few you probably could get them free before they throw them out. I was to late last year. There's also an Amish trailer junk yard down the road from there he had 100's of them in a stack for sale. Maybe worth looking into if your going to Goshen...
Rockwood #8289 WS 2012
F250 6.0 / Husky 16k
With 4 point leveling system
Old 03-23-2016, 08:30 AM   #18
wicked1's Avatar
I meant the electric/hydraulic 4 point jacks with self leveling ability. Figured two up front and two in rear but can't figure a way to mount it and cost is too high. I think the 4 point would lift the Roo right off the ground...lol
Old 03-23-2016, 11:53 AM   #19
Yes it will lift a roo right off the ground, Hydraulic ie 3400 installed 4 point system the electric would run about 2800.00 plus any reinforcing of the frame so you can't twist it. Unless you can find away to take the weight off the tires without lifting them you will always have movement. That's were the electric stabilizers would be good. not the 4 point leveling system IMO...
Old 03-23-2016, 02:15 PM   #20
RooVader's Avatar
I found one x-chock made very little difference. Two made a huge difference. Stacking some boards under the steps was the final piece that had me happy.
XLR 24HFS -> Roo 21DK -> RPod 183g
2013 F150 FX4 EB
RooVader is offline   Reply With Quote
