Old 01-28-2013, 10:45 PM   #21
Terier's Avatar
Extra fuses and cotter pins. At Lowes the cotter pins are about 70 cents each.
Old 01-29-2013, 12:10 AM   #22
SYE
SYE's Avatar
I have a hitch lock on my utility trailer. I also use the pin lock with it. Similar to the one pictured inm this link. I bought the kit at Walmart I believe. I just feel safer where I leave it parked and noone has stole it in 6 years.
Master Lock Universal Trailer Coupler Lock | Towing Locks Hitch Pins| Northern Tool + Equipment
Scott & Vicki
2018 Silverado 3500HD Dually 6.6L Duramax/Allison
2018 Columbus 366RL 1492 Edition
Camped 2012 19, 2013 110, 2014 129, 2015 97
2016 93, 2017 79, 12 Nights Camped 2018 57 nights reserved
SYE is offline   Reply With Quote
Old 01-29-2013, 04:41 AM   #23
Oaklevel's Avatar
I have been RVing for years other than holding the castle nuts in place on the bearings what are you using cotter pins for?? Just asking thought I may be missing something. I learn something new all the time.
2005 Dodge 3500 Cummins
2017 Wildwood Lodge 4092 BFL
1966 Mustang GT
1986 Mustang SVO
Sadie & Lillie Spoiled Rotten Boxers
Oaklevel is online now   Reply With Quote
Old 01-29-2013, 07:59 AM   #24
Some people are confused between (Cotter Pins & R Pins). Youroo!!
Old 01-29-2013, 08:10 AM   #25
Fulltime family RVer
Ohh! That would be me. The first day that I went to the hardware store looking for some backup "cotter pins" left me dazed and confused when they looked nothing like what I had in my hands! In fact, you just taught me that the others are called "R Pins" -- I typically just went looking for what looked like I had!
And yes, some extra "R Pins" are good. I was towing my pop-up the first year. We stopped for lunch. When I did my walk around after lunch, I saw that we were MISSING the R Pin for the coupler/ball latch. I was pretty shocked. Fortunately, our lunch stop was right next to a hardware store! I picked up a replacement and a couple of spares!
ependydad is online now   Reply With Quote
Old 01-29-2013, 08:34 AM   #26
Herk7769's Avatar
Originally Posted by F.R.O.G. View Post
I'm not sure why you have to adjust your pressure regulator when the campground pressure is low. The pressure at your RV is going to be the lesser of the CG pressure or your regulator setting. If you set the regulator at 60 psi and the CG pressure is 30 psi, you'll get 30 whether you open the regulator further or not. On the other hand, if the regulator is set at 60 and the pressure is anything higher, the pressure at the RV will be 60.
It seems to me that you can just set the regulator at 60 psi, or any other maximum that you want, and then just leave it alone.
Yepper!
HAM CALLSIGN - KC3FFW
Old 02-04-2013, 12:31 PM   #27
Canadian Member
itat's Avatar
I'd also pick up:
- something to tie down the awning. I use a couple of ratcheting tie downs with a bright colored straps so you can see them better at night and a screw type peg.
- RV-specific toilet paper
- water heater rinsing wand
For the trailer coupler I use something like this to lock the coupler and to hold up the electrical connection cable and the breakaway switch wire.
http://www.etrailer.com/Hitch-Access...sky/80235.html
I'm like the others here who use 2x12s for under the low side wheels. I have one long enough to sit the 2 wheels on and a 2nd, 2 to 3 feet longer, to go under the first and ramp the wheels up onto the shorter one if I need the extra height.
I also have a couple stacks of cut up 2x12s screwed together for use under the stabilizers. I need them anyway to level the Roo in my driveway so they come camping with us just in case they're needed. I also have one bag of Lynx Levelers. I haven't needed more than that so far.
Old 02-04-2013, 12:40 PM   #28
mike06081969's Avatar
Originally Posted by Dave_Monica View Post
Dave
Believe it or not, I have camped in RV campgrounds that only had 50A/20A power and no 30A. (They conveniently sold 50A to 30A adapters in their camp store.)
Mike in Tennessee
Former 2 time FR owner
2007 Crossroads Cruiser 30QB Fifth Wheel
2008 F-250 Lariat 4x4 6.4 Powerstroke
Firestone Ride-Rites w/cab control
mike06081969 is offline   Reply With Quote
Old 02-04-2013, 03:19 PM   #29
Terier's Avatar
So true. I just got used to calling them cotter pins. If you do a search on cotter pins in MSN (Bing) it will also bring up pictures of R pins too.
cotter pins - Bing
