Old 05-26-2019, 12:00 AM   #1
2019 2604 WS issues
On our first trip out this year, the running lites donít work. Turn signals and brake lights work. So, I guess I will get a battery charger and try applying power to turn on the running lights. First I will clean the contacts in case that is a factor. If the lites donít work, what would be a good troubleshooting process?
The new electronic fixed height TV antenna is of limited utility. It is inferior to the old crank up antenna with batwing. What can one replace it with? The antenna amplifier LED lite is on, so the amplifier should not be an issue.
The radio is mounted near the ceiling. One cannot read the information on the unit because the readout is so dim. It is also not Blu Ray capable. When will FR realize Blu Ray is here to stay?
mlawler506 is offline   Reply With Quote
Old 05-26-2019, 03:23 PM   #2
2019 2604 WS issues
Running lights: Two things to try 1) see if the lights work at the trailer side by using a blade fuse to jump the running lights pin and the 12v pin on the trailer end of the 7way connector. Pic attached Click image for larger version
ID:	205541. If they light up then. It is your tow vehicle or the connector pin may be dirty/corroded on either truck side or trailer side.
If they donít light up then 2) check the wire in the junction box (maybe behind propane tanks mounted on the frame) that connects the opposite end of the 7 way plug to the trailer. I had a wire nut come off once in that junction box and my lights did not work.
2016 RAM 3500 DRW 4x4 LB LoneStar Edition
2018 Chaparral 360IBL w/Andersen Ultimate 2, Tireminder SMART TPMS, Swift Hitch SH04 WiFi Backup/Rear View Camera, Progressive EMS-HW50C
Prior Rig: 2006 RAM 3500 DRW LoneStar Edition
2011 Starcraft 392BHU w/Andersen No-Sway hitch
chaps2018 is offline   Reply With Quote
Old 05-26-2019, 04:20 PM   #3
Thank you for the good input. I got a wire brush and cleaned off the contacts on the caller plug and the issue resolved itself. I will save your diagram for future reference since it would help with diagnostic efforts. Thank you for being helpful.
Old 05-26-2019, 04:21 PM   #4
Trailer plug
