2506S Water Tank Brackets Bent
Filled up the fresh water holding tank to max last trip out. When we got home, i noticed the long brackets holding the tank to the frame were bent downward about 2" in the middle.. You might want to check you mini lite TT for this same condition. Not Good !! The factory should not put "notches" in the brackets.. creates a weak point where it needs to strong .
Clint...
2015 F350 4x4 gasser.. 2017 Rockwood 2506S TT
Ardenvoir, Washington (near Wenatchee)
