04-26-2017, 02:59 PM
2WD or AWD for TV?
Hello,
Looking at upgrading from tent camping to a light travel trailer, possibly an R-Pod. In the process I'm researching potential tow vehicles, preferably 7-8 passenger SUV.
Is AWD recommended over 2WD? What should I consider?
Possibly looking at the following options:
- Honda Pilot (5000lb.)
- Dodge Durango (6200lb.)
- Chevy Tahoe (8600lb.)
Thanks for the input,
04-26-2017, 03:01 PM
They still make 2X4 vehicles?
2017 Puma 297RLSS
04-26-2017, 03:24 PM
First thing is to pick your camper then pick the tv that has the payload wheel base and towing capacity for what you decide for a camper. Also if you are considering the small to mid size suvs frontal area can be an issue too.
Personally I would cross off an and and get a 4wd no sense in powering all the wheels all the time and many of the auto track type systems the power is applied too late to do any good
04-26-2017, 03:49 PM
If it's snowing I'm not going!!
2 wheel drive for me.
Peace!
Dan & Rita D
04-26-2017, 03:56 PM
Thank you Jmkjr72. May I ask for a bit of clarification.
Looking at an RP-178 (20ft long, 3600lbs. 268lbs hitch weight)
What do you mean by that?
Sorry I missed the point here. Do you recommend AWD, 4WD or 2WD?
Apologies for all these newbies questions, and thanks for the help.
04-26-2017, 03:59 PM
You want to look at PAYLOAD capacity on the vehicles you're looking at. If it's 1000lbs and you put a lot of passenger/cargo in it, you will have little to no payload left for a trailer, or it will limit you to a very small trailer.
I agree with others that it's better to decide on a trailer and see what's required to safely tow it.
04-26-2017, 04:47 PM
Scoundrel
I would cross off an and and get a 4wd no sense in powering all the wheels all the time.
A true 4WD vehicle can be switched between 2WD (better gas milage) and 4WD. AWD vehicles typically cannot be switched on or off. The payload capacity of your tow vehicle is most often the limiting factor of what you can pull. Gross Vehicle Weight Rating (GVWR) and Gross Axle Weight Rating (GAWR) refer to the maximum payload capacities of the tow vehicle. By buying a tow vehicle first, you may be limiting what type of trailer you can pull.
04-26-2017, 05:19 PM
My advice would be to first think about the type of camping you will be doing and where, if it improved campgrounds 2 wheel drive will do anything you want, if it is true boon docking then maybe a four wheel drive, it may surprise you how many folks never use their four wheel drive but spend the extra money because it makes them feel safe when they leave the paved road to the gravel drive in a campground. Pick a tow vehicle that will actually fit your future needs not just the camper you are buying. Tent to light camper to ?? JMHO
Retired Navy
2016 Flagstaff 26 FKWS
04-26-2017, 05:32 PM
Unless the hubs lock/unlock (which is not very common nowadays), you are spinning the driveline and mileage doesn't vary much between 2 and 4 WD. My Expedition and Dakota were like that.
My F250's hubs have locking hubs (both manual and automatic), so my mileage varies about 1 mpg between 2 and 4 wd.
04-26-2017, 07:10 PM
I must have four wheel drive, only way to get into our back driveway pulling the FW. My thought is this, it's better to have it and not need it than to need it and not have it.
04-26-2017, 08:08 PM
HUR HUR SO FUNNY!
What sort of situation are you getting your camper in that you need 4x4 to get out of?
04-26-2017, 08:21 PM
Originally Posted by lugoismad
HUR HUR SO FUNNY!
I have to use 4low to back up into a very steep site with gravel roads. Its a great improved CG and great site but very tricky to get into. Wet grass can give you a 2wd headache quite easily.
2016 Ford F250 XLT 4X4 6.2L
Hensley Arrow
04-26-2017, 08:44 PM
Scoundrel
Same here. My driveway is gravel and if I'm not in 4low backing up the hill I'm slinging rocks everywhere.
04-26-2017, 08:49 PM
HUR HUR SO FUNNY!
Wet grass
2017 Puma 297RLSS
04-26-2017, 08:53 PM
A 3600 lb trailer will not have a tounge weight of 268 lbs more like 540 lbs plus the hitch weight 10 to 15 % perfect is 12%
So if you weigh more then 150 lbs add that to the 540 plus the weight of anything else you are going to put in the tv
Frontal are how much surface are re is the front of the trailer take my dodge nitro it's rated for 5000 lbs towing 500 lb toung weight 1150 lbs cargo and 64 Sq foot frontal area. Before I even get started I'm over the toung weight with a wdh hitch I only have 500 lbs for stuff in the vehcile. And if the camper has a front surface area of more then 8x8 it will buck too much wind
A 4wd or area 2 wd
04-26-2017, 08:57 PM
This is so true. Many times, even on dry pavement, 4lo sure helps with needed power and control. I've also had sites that were more mud than gravel and couldn't have gotten in or out without 4wd. I don't NEED 4wd, but I sure enjoy the option many times each year.
Joel and Teresa
2016 Sabre 34TBOK
2006 GMC 3500 CC LB DRW 4X4
HUR HUR SO FUNNY!
Well the state park a few weeks ago I needed 4x4 because the ground was soft and wet. Back in March even at the year round resort with frost coming out of the ground the gravel pad was so soft I needed 4wd. Yes I even need it in the yard if the ground is wet.
It's better to put it isn't 4wd and not need it then to have been n 2WD spin them and grease the wheels up and make it worse
04-26-2017, 09:10 PM
Thanks to all for the insightful replies.
04-26-2017, 09:17 PM
If you want the Pilot, you MUST get AWD and trans cooler to get to 5000lbs. Recommend getting the 6 speed trans over the 9.
Just glad to get away
04-26-2017, 09:27 PM
Honda: I dig their stuff, however a TV is not what I think of when I hear their name! LOL.
