Closed Thread
Old 07-13-2016, 06:07 AM   #121
shorthorn's Avatar
Originally Posted by B and B View Post
Back on track,
Real Post. I had a gas and even with what has happened will not go back.
My 2015 Superduty F 250 6.7 Liter Diesel is sick. There is a hard knocking sound on Regen after the Exhaust display on the cluster. Happens 10 to 20 seconds after the warning goes out. The left side of the engine dumps fuel to get temps up to clean the system.
March 28 a TSB was issued and they flash the computer to turn on both sides. If you have a 14/15/16 get it checked and flashed.
Next week they pull my cab and replace all exhaust valves on the left side.
My truck has always run 30 minute trips twice day and rarely ran a Regen, When towing it never regains so it must be hot enough to burn the particulate up and clean the filter.
Under warranty, 100 percent covered. Just a real life issue. This not a recall but a bulletin for owners. Many a discussion on the Ford Trick Enthusiast Forum. ford-trucks.com
Brian
Brian.... I an curious about this... you will have to keep us updated on the repair and root cause. I am really surprised you mention the motor over fuels to burn off the DPF... I thought all of the big 3 stopped doing that and put an injector in the exhaust to avoid this? I also was under the impression that the modern diesels could vary the VGT on the turbo to bring EGTS up?
2014 RAM 3500 4x4 CCLB Dually, Cummins / 68RFE / 3.42 / B&W Patriot 16K
2016 Coachmen Chapparral 360IBL
SOLD - 2012 Salem Cruise Lite 281BHXL
SOLD - 2005 Dodge Ram 2500 4x4 QCLB Cummins
shorthorn is offline
Old 07-13-2016, 07:40 AM   #122
MarkyB's Avatar
Originally Posted by Kenny kustom View Post
Same arguments every thread.
Diesels are the following;
Noisy. -Not the new ones
Smelly. -Nope.
Cost more. - nope free cummins
Oil changes are more- yup but half as often
Anything else?
2016 Sabre 36QBOK
2015 Ram 3500 CUMMINS
You left out heavy...
I looked at two nearly identical F250 Lariats.
Power Stroke had a CCC of 2000lbs.
6.2L had CCC of 2700lbs.
That's 700lbs of extra engine wt.
Power Strokes are not free, either.
For me, coming from a F150 rated at 1600lb, could not justify a diesel at this time.
Again, it's personal preference and how the numbers look for you, no wrong answer here.
To answer the next question, there were no SRW 350s to be found, so I can only address the actual trucks I looked at.
16 F-250 Lariat 6.2 -- 16 Wildwood 31KQBTS
Nights Camped in 2016 : 25
Nights Camped in 2017 : 20
MarkyB is offline
Old 07-13-2016, 08:49 AM   #123
Wanna Be Camper
SaskCampers's Avatar
Originally Posted by CaptnJohn View Post
X 200. At least 90% of the gasser fans wish they had a diesel but make excuses to make themselves feel better.
Whatever lets you sleep at night I suppose.
John & Deb
2011 Flagstaff V-Lite 30WRLS
SaskCampers is offline
Old 07-13-2016, 12:20 PM   #124
dcheatwood's Avatar
Thread Clean Up & Closure
You may have noticed that several posts on this thread have been unapproved. The site team deemed them non-conducive to the OP's question and resulting discussion.
Thanks to those of you who suggested the OP use the "Search" feature to find one of the MANY threads on this topic.
We only edited about 5-6 pages from the end where most of the non-helpful comments were posted. And, as suggested by more than one poster, this thread will be closed.
Lots of good information here for future seekers. Thanks again.
2018 Forester 3011 DS
dcheatwood is offline
Closed Thread
diesel, gas
